Refinishing Wheels Question (pics)
Old Jun 12, 2007 | 02:29 PM
Dann6968's Avatar
Default Refinishing Wheels Question (pics)
I just picked up a set of older Passat wheels which need to be refinished.
I want to do a very basic polish on them without doing any sanding, just stripping all of the old clear coat and using metal polish. My problem is that there is a small bit of corrosion on parts of the rims where the clear had chipped off. Is there anyway to polish this out without sanding off the tiny machined grooves on the wheels face? I tried with some Mothers metal polish and that didn't work. Maybe something more heavy-duty?
If I do end up having to sand them to get rid of it I'll probably just paint them. Any color preferences? It's for a black ej1.
The first two pics are of the corrosion on a wheel with the clear off and the last pic is of an unstripped wheel (better condition than the first).
Thanks
Old Jun 12, 2007 | 03:21 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Refinishing Wheels Question (Dann6968)
you can try stripping the clearcoat off, then wetsanding it then polishing it.
Old Jun 12, 2007 | 09:41 PM
Dann6968's Avatar
Default Re: Refinishing Wheels Question (E-Rok)
Naw, as I said in the post I don't want to do any sanding. Too much work for what I want and it's also not the type of polish I want.
Anyone know if there is an easy way to get rid of that corrosion?
I think i might just end up painting them.
Old Jun 12, 2007 | 10:03 PM
badboyr66's Avatar
Best advice.... I have done a few...
Aircraft paint stripper works best. The machining grooves will be hard to remove everything from... but take your time it will pay off
If there is metal damage under the clear in into the metal... you are SOL. Either sand them off or paint away
Before
After :DO NOT ASK ABOUT THE CENTERCAPS...I DO NOT REMEMBER
Cereal_Killer
May 6, 2007 01:01 PM
junkyard racer
Dec 1, 2006 03:52 AM
spammy123
Honda Civic (2006 - 2015)
Nov 28, 2006 04:33 AM
dELfONiK
Dec 28, 2005 11:42 PM
jdmspoonitr
Oct 26, 2005 03:57 PM
