help needed, it wont be easy
Old Jun 12, 2007 | 01:33 PM
milkmanLCA's Avatar
Default help needed, it wont be easy
i recently purchased a 93 civic with 59k original miles, sweet, i know. anyways, the 2 driver side doors dont want to open. the back one: i took of the door panel and fucked with the rods and it came lose fast. the rod was too lose. both doors didnt open from inside or outside.
long story short, i fixed th back door, but the front, i cant get the door panel off because of the dash blocking one screw. the lock is stuck in the lock position, and ive almost given up. what to do? advice? i already sprayed lube on the hindge.
Old Jun 13, 2007 | 04:33 AM
milkmanLCA's Avatar
Default Re: help needed, it wont be easy (milkmanLCA)
anyone?
Old Jul 1, 2007 | 03:51 PM
RCautoworks's Avatar
One of the rods should still be connected to the lock area, all you have to do is pull on one from the inside and it will pop the door open. Actually you will have to move one, then pull on the other one.
We are pretty local to you by the way.
Old Jul 1, 2007 | 07:12 PM
milkmanLCA's Avatar
Default Re: help needed, it wont be easy (RCautoworks)
actually i figured it out, the locking mech was jammed, i had to take a long screwdriver and manually unlock it, this was a car that sat for years under a tree. ehh, got it now, and replaced the locking mech and the outside handles. thanks for the only response.
headdles
Dec 9, 2014 12:20 AM
BLeSR
12
Jan 4, 2011 02:26 PM
B20inDCinLBC
13
Apr 21, 2009 10:28 AM
tadashisan
Oct 13, 2008 07:55 AM
ten_30
Mar 1, 2004 09:11 AM
