H2B conversion with a Cable trans in EG
Old Jun 12, 2007 | 11:31 AM
PnkRokCountryboy's Avatar
Default H2B conversion with a Cable trans in EG
Im ordering the COMPLETE kit from evolution industries this friday for my H2B kit in my eg.
My only problem is im planning on using a cable trans..
what do i need to do for the Hydro to Cable conversion
and will the evolution industries kit be sending parts (mounts etc.) that i wont be able to use?
where can i find the correct hydro to cable conversion for my set up
thanks and sorry if i wasnt clear enough
lmk if you have any questions or need more details
Old Jun 12, 2007 | 11:12 PM
Default Re: H2B conversion with a Cable trans in EG (PnkRokCountryboy)
need help with this guys im prdering parts this friday!
Old Jun 13, 2007 | 07:06 AM
turtleman321's Avatar
my guess is they would be sending stuff you wont be needing. i think your only going to be able to do hydro to cable with custom mounts or QSD kit because it uses be series mounts and you can just use any b series hydro to cable conversion mounts
Old Jun 13, 2007 | 08:40 AM
2slowGs-R's Avatar
hey i was wondering why you would want cable instead of hydro. You know hydro is the way to go because its so much easier and better right? Shifting is all up to the person on how fast you can switch, same thing with cable but its actucally not like hydro the way it pulls into gears.
Old Jun 13, 2007 | 09:39 AM
Default Re: (2slowGs-R)
yeah ive had both in some of my past cars..i like the cable trans
and plus right now im getting hooked up on it so i cant pass it up by any means
any advice is appreciated!
Old Jun 13, 2007 | 10:14 AM
Default Re: (PnkRokCountryboy)
i found the conversion through hasoport..my next question is, are the mounts that are used just b series mounts all around (the mounts that are included in the H2B kit)
Old Jun 13, 2007 | 01:39 PM
SIXTY's Avatar
your only going to be able to use those hasport mounts with the qsd kit, because the trans is in the same spot as with a b-series motor. The evolution kit moves the postion of the tranny, so you have to use their mounts or it wont line up properly.
ben.batiste
Nov 30, 2009 12:32 AM
ProjectRustyEF
Jun 24, 2008 10:29 AM
Crx_B1turbo
Sep 12, 2007 02:02 PM
RI_TM
Jul 8, 2004 02:13 PM
