Lighting HID/Xenon kits, Retrofits and Associated Topics
How to install aftermarket HID kit in one picture.
Old Jun 12, 2007 | 10:51 AM
OMG THE GOGGLES's Avatar
Default How to install aftermarket HID kit in one picture.
I made this diagram for those confused on how to correctly setup their HID setup, figured I would post here. If it helps even just one person atleast it was worth making.
Old Jun 12, 2007 | 12:13 PM
alltech_hybrid's Avatar
Default Re: How to install aftermarket HID kit in one picture. (OMG THE GOGGLES)
ummm nice but what does it have to do with paint and body?
Old Jun 12, 2007 | 12:54 PM
Default Re: How to install aftermarket HID kit in one picture. (alltech_hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alltech_hybrid &raquo;</TD></TR><TR><TD CLASS="quote">ummm nice but what does it have to do with paint and body? </TD></TR></TABLE>
Find a better section to put it in, honda-tech doesn't have an electronics section, and this section has plenty of topics about lighting..
Old Jun 15, 2007 | 03:27 PM
DB1_559's Avatar
hell good info just orderd my hid's
Old Jun 15, 2007 | 06:37 PM
98GSRDC2's Avatar
Default Re: How to install aftermarket HID kit in one picture. (DB1_559)
to tell you the truth, its not even that hard to put in hids. its just as easy swapping light bulbs
Old Jun 15, 2007 | 09:52 PM
Default Re: How to install aftermarket HID kit in one picture. (98GSRDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98GSRDC2 &raquo;</TD></TR><TR><TD CLASS="quote">to tell you the truth, its not even that hard to put in hids. its just as easy swapping light bulbs</TD></TR></TABLE>
Yes, and if you dont wire it in as above with the relay you can easily melt your stock wiring harness'
Old Jun 16, 2007 | 02:38 PM
hatch96y7's Avatar
okay i understand everything except where u plug it in to ur stock harness the plug i have is just like the one pictured but my light harness is a three prong and that one is two.
do i connect it directly to the bulb harness or somewhere else
Old Jun 16, 2007 | 02:39 PM
hatch96y7's Avatar
Default Re: How to install aftermarket HID kit in one picture. (hatch96y7)
that last connection on the bottom right of the pic
Old Jun 16, 2007 | 05:30 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
We need to rename it the "Paint and Body Work Forum."
Moved.
Old Jun 16, 2007 | 05:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">that last connection on the bottom right of the pic</TD></TR></TABLE>
Dependent upon the kit you get, you should have a different harness plug. Say for an example, a 92-95 civic with an H4, its a 3 prong plug so you should have an h4 connector to wire it into. If you do not, then you would simply cut the 2 prong off of the end of the hid kit, match a positive and negative feed, and connect. Should pretty much be plug and play though. Post pics and I will try and help you asap. Just pm me.
Old Jun 22, 2007 | 12:13 PM
menappi's Avatar
Nice pic =D
Old Jun 22, 2007 | 02:41 PM
DB1_559's Avatar
aye do you have to cut a new hole for the hid cause mine do???
Old Jun 22, 2007 | 02:47 PM
DB1_559's Avatar
nvm
Old Jun 22, 2007 | 07:13 PM
menappi's Avatar
hehe.
Old Jun 26, 2007 | 01:15 PM
No cutting needed, only drilling to securely mount your ballasts.
Old Jul 11, 2007 | 08:45 PM
boostedeghatch's Avatar
thanks for that pic
Old Jul 12, 2007 | 06:34 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: How to install aftermarket HID kit in one picture. (boostedeghatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMG THE GOGGLES &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, and if you dont wire it in as above with the relay you can easily melt your stock wiring harness'</TD></TR></TABLE>
I never knew that. Ive had mine in for about a year and the harness is fine
Old Sep 20, 2007 | 06:45 PM
Scrappy_jm's Avatar
this makes things look much easier than i thought lol
Old Sep 20, 2007 | 08:13 PM
Default Re: How to install aftermarket HID kit in one picture. (Scrappy_jm)
Glad this pic-tutorial I made is still helping people out, that was my intention.
Old Sep 21, 2007 | 01:48 AM
goonzoo's Avatar
tnx for the pics and an amazing how-to.
it's naturally easy to install HIDs.
it's just a matter of knowing where to plug it in.
nice pics nevertheless
Old Sep 24, 2007 | 08:12 AM
jdm94_civic's Avatar
Default Re: (goonzoo)
plug and play hid kit ! dont get pulled over with those ! big ticket $375 ..... i sold my kit
Old Sep 25, 2007 | 09:35 AM
xionl1350's Avatar
very helpful picture
Old May 28, 2008 | 08:47 AM
White Smoke's Avatar
i my honda
Global Mod
Default FV-QR
This deserves a bump!
Old May 28, 2008 | 08:59 AM
Default Re: FV-QR (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">This deserves a bump!</TD></TR></TABLE>
Tanks!
Old Jun 8, 2008 | 11:01 AM
leadfootedfool's Avatar
Default Re: FV-QR (OMG THE GOGGLES)
Great pic!
