Removing rear seat on 92 accord
Old Jun 12, 2007 | 10:36 AM
jdadams12's Avatar
Default Removing rear seat on 92 accord
How can I do this?
Is there any chance that I could put an amplifier or two under there?
Old Jun 12, 2007 | 04:31 PM
Bruce Banner's Avatar
Default Re: Removing rear seat on 92 accord (jdadams12)
no, u won't b able to put an amp under that.
Old Jun 12, 2007 | 05:10 PM
JDM_DC4_Fanatic's Avatar
Default Re: Removing rear seat on 92 accord (Bruce Banner)
to remove the seat, you have to remove the back first. There are 2 side cushions, one on the left, the other on the right. Push down on the bottom seat cushion just under these side pieces, and you'll see 1 10mm bolt, remove 1 bolt on either side and slide the side panels up and out. there are 4 screws holding the rest of the back to the car. 2 on each side of the seat, again 10mm bolts.
to remove the bottom cushion, there are 2 10mm bolts at the back of the cushion. remove these bolts, filp the seat cushion up and forward, and pop it out.
Something to keep in mind, when you take the seat out, there is a ground for the fuel pump with a 10mm bolt on it. Make sure that you do not disconnect that ground and forget to put it back on, the car will not start.
First remove the bolt under here:
Push down on the seat coushin, and you should see this:
Then, once they are removed on both sides, the seat back would be secured here on both sides:
This is the 1 bolt for the seat bottom:
And this is where the fuel pump is grounded, NO NOT REMOVE!!!
Old Jun 13, 2007 | 11:50 AM
92ACCORD_CB7's Avatar
You can always have it under the shot gun and driver seat. Thats what I seen some people do, aight laters.
Old Jun 13, 2007 | 12:41 PM
Default Re: Removing rear seat on 92 accord (92ACCORD_CB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ACCORD_CB7 &raquo;</TD></TR><TR><TD CLASS="quote">You can always have it under the shot gun and driver seat. Thats what I seen some people do, aight laters.</TD></TR></TABLE>
It would have to be a small amp
fusion645
Apr 4, 2011 01:27 AM
airikkCRX
Aug 14, 2010 05:36 PM
BrayzieEF9
Jan 6, 2010 08:17 AM
jgrif08
Oct 23, 2006 06:08 PM
Ckleijne
Oct 29, 2005 11:15 PM
