Loud Screeching Noise when starting Car?
Old Jun 12, 2007 | 09:36 AM
bsivoljr's Avatar
Default Loud Screeching Noise when starting Car?
Sorry guys Im a Newb but I learn fast, Just never had a car until about a month ago.
Never had one to deal with ya know, finally bought one Independently. Saved up the money. 1990 Accord Lx.
I bought a problem, but I know you can work Magic with Hondas. Well what Im trying to figure out is How come when I start the car it screeches for about 30 seconds. Since I bought it every day it screeches longer and longer when I start it up. At first it was only like 3 seconds. When I step on the gas it stops screeching faster. When I have driven it, turn off, then start again. If not too long since last time running, it screeches for about 5 seconds and when I step on gas it stops. I know your thinking the belts but when I look at the belts they have no visible cracks? or obvious ware inside or out. When I spray belt dressing on them, it sounds a little better, and stops faster. Do you think they are loose?
Old Jun 12, 2007 | 10:13 AM
jdadams12's Avatar
Default Re: Loud Screeching Noise when starting Car? (bsivoljr)
It is most likely the belts still. You can also get this of any of the accessory bearings are going out - like AC Clutch, PS Pump or Alternator.
Does this happen even when the AC is off? If so, then I would look elsewhere than the AC/Alternator belt.
Old Jun 21, 2007 | 11:18 PM
bsivoljr's Avatar
The AC doesn't even work
Old Jun 21, 2007 | 11:44 PM
pos_cd5's Avatar
Default Re: (bsivoljr)
if belt dressing didnt help try tightening the belts. IIRC there should be a belt tensioner for the serpentine belt. if not...then replace the belt.
jamesmoua
Honda Civic (2001 - 2005)
Aug 7, 2017 05:13 AM
valoskater420
Feb 4, 2014 10:55 AM
BlueLude84
Jan 13, 2007 11:59 AM
idriveadelsol7
10
Sep 4, 2005 12:14 PM
jonoknut
Feb 19, 2003 09:24 PM
