Suspension & Brakes Theory, alignment, spring rates....
IT-R Rear Sway Bar on a GS-R!!!
Old Jun 12, 2007 | 09:24 AM
silver_gs-R's Avatar
Default IT-R Rear Sway Bar on a GS-R!!!
hey guys,
as the title states I am thinking about throwing a IT-R Rear Sway Bar on my GS-R.
so basically what it comes down to, has anyone on here attempted this modication, and what parts did it consist off.
now this is what I'm thinking I need:
-itr sway bar
-bushings
-end links (which ones its or gsr???)
but something you guys should know aswell that I will be putting on skunk2 rear lower control arms and a skunk2 rear lower tie bar???
so I just need you guys to answer my question, if all this will in fact work together, and will I need anything else.
thanx in advance
alex
Old Jun 12, 2007 | 10:12 AM
Relic1's Avatar
rear subframe support is advised with the ITR rear bar. see ASR subframe brace.
also, a very quick search results in quite a few how-tos on this exact mod.
http://integramod.tripod.com/p....html
Old Jun 16, 2007 | 04:34 PM
jonni2000's Avatar
or use the obx subframe, it can support 22mm sway bar, much cheaper if you are not going to go 24mm or more
Old Jun 16, 2007 | 05:15 PM
numbnuts22715's Avatar
or beaks, or bsq? i believe its called.
I did this a while back.
If you have a gsr, all you need are the bushings, d brackets i believe their called. Everything else will bolt right up.
For the beaks or bsq, you have to remove a few tackwelded nuts, which isnt that bad.
it makes a HUGe difference.
null.
Aug 7, 2004 12:03 PM
gabspeed
Mar 17, 2004 04:39 AM
B_CRUZ!
Jul 9, 2003 05:35 AM
animated_life
Sep 27, 2002 03:10 PM
Mr. Softee
Jun 25, 2002 03:01 PM
