where is turn signal flasher located in fuse panel?
i looked in the owners manual and behind fuse panel cover but where is the turn signal flasher locaed at.
and does anyone know where i can get an electronic flasher for the 07 fit..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07fitsport »</TD></TR><TR><TD CLASS="quote">i looked in the owners manual and behind fuse panel cover but where is the turn signal flasher locaed at.
and does anyone know where i can get an electronic flasher for the 07 fit..</TD></TR></TABLE>
For anyone that wants to know where the flasher is here's the link to where it is along with pics. http://www.fitfreak.net/forums/87238-post9.html.
You won't be changing that easily. You'll have to go with load stabilizers to run LED turn signals, 50 watt 3 Ohm 1 for each side.
j-rome
Sep 13, 2006 11:29 AM
