Need some help for my sohc zc ef9!!
Old Jun 12, 2007 | 02:49 AM
zcsport's Avatar
Default Need some help for my sohc zc ef9!!
my car doesnt idel's good when it warms up,the rpm keep reving from 1000 to 1500 then drops back to 1000...and my ecu is throwing out code 8 and 15 which are TDC sensor for my dizzy and ignition output signal.those are what i found out on this site but i don't really get what it means because my dizzy is pretty new..any one can give me some sugguestions for my car and by the way my car backfires a little bit and does that have something to do with those code that i have??what ring do i need to replace or sealed if i got some oil on my spark plug..thanks for looking!!
Modified by jdmhbef at 4:05 AM 6/12/2007
Old Jun 12, 2007 | 03:05 AM
Dancing is Forbidden's Avatar
Default Re: Need some help for my sohc zc ef9!! (jdmhbef)
what sohc zc is it? isnt there a couple? Also, did you do any wiring when installing this engine? If so check that. If not go to this page http://www.clubcivic.com/board...90486 and check for a ground fault between your distributor wiring and ecu
Old Jun 12, 2007 | 03:20 AM
zcsport's Avatar
Default Re: Need some help for my sohc zc ef9!! (Dancing is Forbidden)
sohc zc is a rare old engine that's what i knew well thanks for your info i will check that later!!
crxguy406
May 6, 2012 04:16 PM
b16dc2
May 4, 2008 10:25 AM
ludesrv
Feb 20, 2006 08:11 AM
r0cket247
Feb 9, 2004 02:02 PM
Leets
12
May 13, 2002 01:24 PM
