will a 90-93 rear sway bar fit on my 88 crx?
I would think that it would. You may have to change the rear LCA to mount the sway bar and get the brackets that mount to the frame but other then that it should be the same. I have one on a 90 STD and after getting new LCA's and mounting brackets it bolted right up. You can try to drill the teg brackets but thats alot of work and still didn't look like it would have worked. I may be wrong have been in the past if I am just lemme know.
The biggest problems with the CRX (DX & HF) are 1. the lca's are not threaded for the end links and 2. the nuts are not welded in for the brackets. So to put the sway bar on either of those you will have to fabricate some brackets for the sway bar as well as switching to Si lca's. If he has an Si he could switch over to the integra bar. There may not be any real advantage to switching. The Si and 2 door integra bar are the same size. I looked into this a while back and found that the 4 door sway bar may be a little bigger. Unfortunately, I have not been able to verify this.
[Modified by wronghand, 11:00 AM 6/5/2002]
crexer
Aug 30, 2004 07:03 PM
martini
May 20, 2004 08:44 PM
