Engine Swap Question
Old Jun 11, 2007 | 07:38 PM
Paulie Pesos's Avatar
Default Engine Swap Question
I have a 94' civic with the 1.5. I Just got a 1994 Integra B18B1 engine with the ECU and tranny and it looks like i will have to do this all myself. When looking around, all I could find is B18C1 swap info. Can someone explain what i will need to do... Im not fully retarded, i do know about axels and all that but my biggest concern is wiring... Can i use my stock wiring harness?
Old Jun 11, 2007 | 09:57 PM
Bejita's Avatar
Yes.
Old Jun 11, 2007 | 10:04 PM
daluv's Avatar
Default Re: (Bejita)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">Yes.</TD></TR></TABLE>
X2
Old Jun 11, 2007 | 10:08 PM
Bejita's Avatar
But you will need a different ECU.
JesusGLS's Avatar
Default Re: (daluv)
well....im hoping you dont forget about the mounts, shift linkage, etc..
Old Jun 12, 2007 | 10:00 AM
elmo908's Avatar
it doesn't say if you are in cali but if you are you want to have stock integra ls emissions components hooked up.
Old Jun 12, 2007 | 10:12 AM
crazyguy's Avatar
Default Re: Engine Swap Question (Paulie Pesos)
you will need the axles..new mounts..and half shaft if it does not come with the engine.
Old Jun 12, 2007 | 09:56 PM
daluv's Avatar
*92-01 Integra ECU
*Match your axles with the intermediate shaft you get (i.e. if you get a 94-01 integra intermediate shaft, use 94-01 integra axles, if you get a 90-91 intermediate shaft, use 90-91 axles, and if you get a 92-93 intermediate shaft, use 92-93 axles)
Also Ive heard that the passenger side axle is the same through all years (90-01) but the drivers side is the one you need to match the intermediate shaft, you might want to research on that.
*94-01 integra reat motor mount bracket (a black t-shaped bracket that bolst the motor and tranny to the rear motor mount)
*I suggest getting after market mounts for a B-series into an EG, But Ive heard that the drivers side D-series mount will work
*Your stock D-series top tranny mount will work for a b-series hydraulic tranny, Ive used one in my EG with an Ls motor with a GSR tranny
*Ive heard that the rear motor mount from a 94-01 will work, but again, I suggest getting the aftermarket one that comes with most aftermarket mount kits
*Your stock wiring harness and engine harness will work, just make sure you have an OBD1 LS distributor and OBD1 fuel injectors
I think thats it, all I can remember off hand that is. Good luck!
Old Jun 12, 2007 | 11:39 PM
d15-jdm-civic's Avatar
Default Re: Engine Swap Question (daluv)
all B series swaps should be the same into any EG cause the DC2 and EG have pretty much the same layout, ive got a 97 B18C in my 93 civic dx and all i used was stock DC2 mounts and Stock DC2 axles and DC2 shift linkage but i agree with him ^^^^ you might as well do after market mounts unless you dont want your car to vibrate its *** off, then try new stock DC2 mounts for a nice stock feel.
Old Jun 13, 2007 | 07:50 AM
daluv's Avatar
If you do use stock mounts, get polyurethene inserts for them. I think energy suspension makes some.
liquidx
Aug 7, 2007 06:20 PM
Dream_Seeker
Jan 11, 2005 04:09 PM
white99si
May 3, 2004 07:26 AM
