507M Wiring to 5900 Optional Sensor 2
Red wire - 12v constant
Orange wire - ground output when armed or constant ground.
Blue wire - instant trigger or green wire from the shock sensor
it is not recommended any other wires from the sensor input
I understand the 12v constant and ground output
but what about the 507m blue wire, does it connect to the loose green wire coming from the sensor, or do I have to cut the loop and connect it there
the shock sensor is a 4 pin connector and the green wire with the loop share's the same pin with the blue wire and has it own pin
I cut the green loop and connected the blue wire on the tilt sensor to the grren/blue wires (pin 3) and then I tried the single green wire (pin 4)
and it still doesn't work either way
juanchoenuncrx
Aug 24, 2007 04:48 AM
