FS: 92 CX - Toda, Mugen, Tein, Autopower, Orijin, HardRace, Falken, Track Ready - l00k!!!
Some pix0rs to start it out, ill get better ones per request..
BTW: if you wanna steal my car based on license plates, have fun.. theres just a busted camry in the garage there anyway
PRICE - $8,000 OBO - PM me to talk pricing
Engine
- 1999 B18c1 (Built by Steve Sakai, sGT Racing)
- JDM ITR OS .25 Pistons/Rings
- Shotpeened GSR Rods
- New Bearings, Gaskets, Seals
- New Oil Pump, Water pump
- New Timing Belt
- New Head gasket
- Toda Header
- Skunk2 Intake Manifold
- B&M Fuel Pressure Regulator
- OBD-I Prelude 290cc Injectors
- Del Sol Dual Core Radiator
- Endyn Breather
- Mugen Oil pan
COMPRESSION RESULTS: 250, 243, 245, 250
Only known problem is a driver side axle seal leak – its about $30 from Honda and an hour of your time.
Exterior
- JDM EG6 Headlights/Corners
- JDMshit Mugen Front Lip
- VIS Carbon Fiber Duckbill Wing
- Circuit Hero Front/Rear Tow Hooks
- ‘Tow’ stickers
- Spoon ‘style’ side view mirrors
- WeatherTech Window Visors (driver side broken)
Rollers
- 15*7 Team Dynamics Pro Race 1.2
o spray painted takata green, some paint has flaked off
- Falken Azenis RT-615’s 95% tread
Suspnesion
- Tein RA’s 12k/14k Spring Rates
- 92-95 Civic SI Front LCA’s
o Orijin Spherical LCA Bushings
o Includes 21mm Front Sway (not installed)
- Orijin Hardened Rubber UCA Bushings
- HardRace Spherical Rear Trailing Arm Bushings
- HardRace Spherical Toe Adjusters
- HardRace Spherical Rear Camber Adjusters
- 22mm ITR rear Sway bar + Beaks Reinforcement Kit
- Car has been professionally aligned at Curry’s Automotive in Chantilly, VA with the toe/camber set to my specifications (will include alignment sheet)
Brakes
- 4 Wheel Disc Brakes All Around (GSR)
- Integra RS 15/16th Master Cylinder
- Good Ridge Stainless Steel brake Lines
- Cobalt GT+ Sport Brake Pads Front/Rear
o Front – 30% left
o Rear – 80% left
- Remanufactured Front GSR Calipers
- ATE Super Blue Fluid
Interior
- No interior panels or carpet
- All Tar has been removed, and smoothed over floorboards
- Interior painted ‘New Ford Grey’ or ‘Battleship Grey’
- Sparco EVO Driver-Side Bucket Seat
- Custom Made Low-Position Seat Rails w/OEM Sliders
- Integra Cloth Passenger Seat
- OMP WRC 350mm Red Suede Steering Wheel
- Momo Hub
- Autopower Race Rollbar w/Weld in Diagonal and Harness Bar
- Ioport Camera Mount for Rollbar
- Sparco Harness Hardware (not installed, but included)
- OEM Honda Block Off Plate
NOTES.
1. Car has about ~80k Miles, owner changed the gauge cluster from the stock CX cluster to an SI cluster at around 69k miles
2. NO RUST
3. Body of the car I would give a 7 out of 10
4. This car would make a great track car or weekend driver - with a few modifications could also be prepared for Honda-Challenge Racing H2 LPV
5. If you have a problem with the price, PM me to talk about it – Can’t hurt.
6. This car is barely driven by me, I hate to see it sit in my garage anymore and not driven! Car is completely registered and also has passed safety around my area (friends help)
7. Car has been 100% Reliable on the track for me, and spirited driving on the weekends.
8. Car is a serious blast to drive on the track, some honda-tech member have instructed me before and can vouch for the car... you should buy it and chase down some high dollar bling at the track, and then laugh as you drive it home too
THANKS again!
Engine
- New Timing Belt
- New Head gasket
- Toda Header
- Endyn Breather
- Mugen Oil pan
Exterior
- ‘Tow’ stickers
Rollers
Suspnesion
Brakes
o Front – 30% left
o Rear – 80% left
Interior
- Momo Hub
NOTES.
2. NO RUST
!PRICE - $8,000 OBO - PM me to talk pricing
THANKS again!
forgot about even more bling..
Toda Flywheel
Exedy Organic Clutch
Toda Flywheel
whoever buys this car would be very happy
