JUST CHANGED HEAD GASKET...NEED HELP PLEASE
I BLEW A HEAD GASKET 2 WEEKS AGO AND ALREADY CHANGED EVERYTHING INCLUDING GETTING THE HEAD RESURFACED......I PUT EVERYTHING BACK TOGETHER WITH THE PROPER TQ.SPECS AND DID EVERYTHING RIGHT THE TIMING IS ALSO DONE RIGHT...IT CRANKS BUT WONT START SO YEAH ANY HELP WILL BE MUCH APPRECIATED
THANKS
THANKS
You have 2 choices.
1. Explain better what your problem is.
2. Make a video and host it and post it here so we could know whats going on.
yes there is spark and fuel
thats the thing there is everythign needed for a motor to turn over but its not doing it.....its just cranking
sometimes it takes a little to start up,when my buddy had his D16z6 laying around and decided to boost it,well once put it was in it took about 30 seconds to actually turn on so if your getting sparks and fuel is going in keep it turned for a while
a video i a no go i have nothing to do such things...lol
and im tryign the best i can to explain it im kinda stressed about it right now so i appolojise for my lack of explination...so if you can help at all please ask me what you want to know...
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93gunner »</TD></TR><TR><TD CLASS="quote">sometimes it takes a little to start up,when my buddy had his D16z6 laying around and decided to boost it,well once put it was in it took about 30 seconds to actually turn on so if your getting sparks and fuel is going in keep it turned for a while</TD></TR></TABLE>
LoL
No, that's not normal for a boosted motor nor a stock one.
LoL
ok so i decided instead of trying to figure it out with out knowing what it could be i just took the head off again so i could start over again...also i wanted to make sure that when i did the timeing that i diddnt do it wrong and hit the valves.
it all looks good...so ill get back with all of you in a day or so....also any suggestions any of you have would be appreciated.
thanks
thanks
make sure the timing is correct, firing order, and all cables connected and it should fire right up. unless you have another problem that you do not know about that has nothing to do with the removal/installation of the head.
Im not sure if the distributor has the same drive system, but on the D16 the Dist. fits into a slot on the cam. try taking the dist. off and flipping the rotor 180º and bolt the dist. back on.
I had the same problem when i did my head gasket like a week ago... i got everything back together, timing corect, and all the motor would do was crank. i knew that the dist. might have gotten moved from its original position from the head removal and sure enough it did.
luckly theres only 2 ways it can go on
did you pull the spark plug wires from the distibuter? if so you probley got them in the wrong order, thats the only thing i can think of is if you have fuel,spark air, and compresson than thats it. also check your timing with a timing light.
blinger
Apr 14, 2007 03:24 PM
Red93AWD
10
Aug 16, 2005 06:45 PM
