Adding A/C to a ef
Hey was up HT i have a 1990 Ef that i swap a 01 Ls engine in it. i was woundering if is possible to add A/c? Cuz H-town is to hot ride with no a/c. If so then can i use the same line of a regular ef or do i need the one for a 01 a/c line?
Thanks
Thanks
You would use all of your stock a/c lines. The only thing you'll need is the compressor adapter to fit your EF compressor to the B-series block. Hasport sells them.
I am also looking into this area. Except i am with out any of the AC parts.
Not to jack your post.. I am just hoping i can get some information in the same ideal post about ADDing A AC to our vehicals.
Anyone know if any other honda/acura AC parts will fit the 88-91 crx? I am thinking this is a long shot, but who knows I may learn something new. If so know anyone parting out an AC
Thanks guys
seth g
Thanks guys
seth g
If you're looking to stay stock, you can only use the 88-91 Civic/CRX parts. Anything else may be possible but would involve building custom lines and a lot of mixing and matching.
Otherwise, if you have a D-series engine, use all the stock equipment. If you have a B-series, you can use the stock compressor with an adaptor bracket as mentioned above. Anything elsem you're on your own.
all good then.
I will hunt down a stock 88-91 AC piping parts then.. and then that hasport adapter =0)
If anyon knows of a website on the stock AC unit for sale .. send it my way
thanks
thanks
hey im from corpus and its hot as sht down here too. i just sold my crx with no ac to get an EK with a b16 and no ac..but im in the process of getting it together, its not going to be easy
