205/55-15 on a stock height 01 civic
Hello all,
I'm considering installing 205/55-15 tires (Bridgestone RE750) mounted on 15x6.5 wheels onto a 01 civic ex coupe. The car currently has stock springs and KYB red struts. Will I have any issues with tire rubbing with the 205? I did a quick search of this forum but did not find anything on 205s.
Thanks for any help
Thanks for any help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03turboem2 »</TD></TR><TR><TD CLASS="quote">i just ordered a set of 205/50R15s for my car
too small, should've done 55
</TD></TR></TABLE>too small, should've done 55
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 »</TD></TR><TR><TD CLASS="quote">
too small, should've done 55</TD></TR></TABLE>
Yep. Even the 205/55/15 is a bit shorter than the oem tire. I put some 205/50/15's on the car once just to see how it looked, and the tire was too short to use as a daily.
There is no reason to stray from the oem diameter unless you have a specific purpose in mind.
Yup, it is too small.
I put a 205-50-15 (it was much cheaper to find in that size than others) - but I found that the speedo isnt off my much.
@ 45 mph, it was only off by 1 mph. @70, around 2 mph.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efficiencyJunkie »</TD></TR><TR><TD CLASS="quote">Yup, it is too small.
@ 45 mph, it was only off by 1 mph. @70, around 2 mph. </TD></TR></TABLE>
Actually compared to stock, you're 4.9mph off at 60mph.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmorris05 »</TD></TR><TR><TD CLASS="quote">I have 215/40/R17's on mine ...</TD></TR></TABLE>
too small.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LatinEM1 »</TD></TR><TR><TD CLASS="quote">How about 205/60/15 on Si's rims</TD></TR></TABLE>
oem spec, i'd go with 205/55/15. it's the perfect size IMO.
too small.
too small.
oem spec, i'd go with 205/55/15. it's the perfect size IMO.</TD></TR></TABLE>
You think they will look good on my s-tech's? i have 60's right now, but need to get new tires cuz one has a bump/bulge on it
too small.
The 55's will look just fine. But, in all honesty, I'd stick with the 60's, since it'll keep your speedometer accurate, and also give you a shade better fuel mileage (less rotations to do certain speeds).
</TD></TR></TABLE>The 55's will look just fine. But, in all honesty, I'd stick with the 60's, since it'll keep your speedometer accurate, and also give you a shade better fuel mileage (less rotations to do certain speeds).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">
The 55's will look just fine. But, in all honesty, I'd stick with the 60's, since it'll keep your speedometer accurate, and also give you a shade better fuel mileage (less rotations to do certain speeds).</TD></TR></TABLE>
Cool, and also the 60's are cheaper on tirerack than the 55's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">
There is no reason to stray from the oem diameter unless you have a specific purpose in mind.</TD></TR></TABLE>
Thanks for your and everyone elses input!
You are correct the 205/55 is about 1.87% smaller circumference (a 205/60 is about 1.5% larger) than a stock 185/65. I felt since I was going wider, there would be less chance of interferece with a slightly shorter tire than a slighter taller tire. The main reason for the 205/55 is that the RE750 is available in that size. There are very few z rated (or better) tires available in stock diameters other than the 205/55. I am quite familier with the RE750 on other vehicles. It is a tire that meets my needs nearly perfectly.
Having said that, I would be open to using a 195 tire if some knows of a 195/60 that is a summer Z rated performance tire comparable to the Bridgestone RE750.
Thanks again for all the input!
On my '01 the OEM spec size is 185/60/15, currently have 205's though and I love em.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G »</TD></TR><TR><TD CLASS="quote">im on OEM specs on my stock SI's and now that im dumped, it looks wayyyy better than i thought it would. If only i wouldnt scrape over everything...
NO PICS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Psychochik »</TD></TR><TR><TD CLASS="quote">
On my '01 the OEM spec size is 185/60/15, currently have 205's though and I love em.</TD></TR></TABLE>
oh yeah, sorry, forgot stock was 185
</TD></TR></TABLE>NO PICS?
On my '01 the OEM spec size is 185/60/15, </TD></TR></TABLE>
That is interesting. Are you referring to a '01 Civic (sold in the US)? The '01 Civic EX Coupe I am working on came with a OE size of 185/65-15. That is consistent with the info in the owner's manual. If the OE size is a 185/60-15 then a 50 series 205 would be the size closer to the stock diameter, not the 205/55 I was considering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">The older 7th gens came stock with a 185/70-14 or 185/65-15 . Later that switched to a 195/60-15.
That makes sense. That was my understanding as well. All three of those sizes have a very similar diameter.
Thanks for clearing that up
