Euro-R IM MODIFIED TO WORK 100% WITH A USDM H22, brand new!!
All of the best work
All of the best parts
and best of all NO WAITING!!!
Now is your chance so save $$$ on a great intake manifold for your H22
-Brand new H22 Euro-R intake manifold, purchased new from hmotors
-Brand new RC 370cc fuel injectors, peak and hold (for OBD I)
-ITR throttle body modified by MAXBORE, 70mm at opening, modified to 64mm
port matched to IM opening by maxbore
-port matched OEM Honda throttle body gasket
-Euro-R throttle cable bracket
-Modified by member 2point6, Scott at Collective Racing for use with a USDM H22
-Very extensive modification, cost me $300 alone. Includes modification of
injector ports, custom IACV install, and custom fuel rail mount
-JDM H22 fuel rail
-KMS Engineering EGR block off plate
-Hondata IM gasket
-All sensors and IACV are included
Only the IACV and throttle body are used. All other parts are Brand new
I have around $1350 invested in this setup, I'm obsessed with having things done right the first time.
I'll let everything go for $900 with injectors, or $750 without
I WILL NOT PART THIS OUT unless offered alot of money to do so
All lowballs will be ignored. Serious buyers know what this is worth
-JDM H22 fuel rail
-Hondata IM gasket
Forgive my ignorance please, when you say "modified to work 100% with a USDM H22" What do you mean? Is that for the brackets and fuel rail inlet?
so its drop in then. you already modded everything? cool beans if it is i am intrested but it might be a week before i can purchase
DDTECH
Sep 16, 2013 01:16 PM
DDTECH
Texas -OK -LA (Sales)
Sep 9, 2013 03:59 AM
