question on retro fitting a/c
Old Jun 11, 2007 | 07:39 AM
powderb18b's Avatar
Default question on retro fitting a/c
i have a 94 honda civic with a b18b, i was wondering which compressor (d or b series) and which a/c bracket to use. i had "heard" that i could use a del sol b16 a/c bracket but im not sure if it will work. i know HT has very knowledgable techs and diy'ers so i appreciate the help!!!
Old Jun 11, 2007 | 07:50 AM
1.6vx's Avatar
you got it or the crv bracket will work too. Got mine on ebay for 60bucks.
Old Jun 11, 2007 | 11:11 AM
powderb18b's Avatar
Default Re: (1.6vx)
what compressor did you wind up using, and which would you recommend for my ej?
Old Jun 11, 2007 | 11:38 AM
DCteg505's Avatar
im sure you can use your d compressor and mate it with a crv or del sol bracket
Old Jun 11, 2007 | 12:00 PM
h8ted ek's Avatar
Default Re: (DCteg505)
you could stil use the integra bracket with the b series compressor but when its aligned only two bolts hold up though.
let me take that back im refering that method to the 96-00 civics
Modified by h8ted ek at 1:24 PM 6/11/2007
Old Jun 11, 2007 | 12:16 PM
pdiggitydogg's Avatar
as stated:
Get the CRV (P7J) front bracket and you can use your D series compressor
Old Jun 11, 2007 | 12:20 PM
crazyguy's Avatar
Default Re: question on retro fitting a/c (powderb18b)
use del sol or crv or 99~2000 civic si or dc2 inegra ac bracket and u can keep using your d series whole ac set up
Old Jun 11, 2007 | 12:23 PM
h8ted ek's Avatar
Default Re: (pdiggitydogg)
whatever works man, that route you'll want to take is from the above poster. But i was referring to other alternatives in case others are reading. plus b series condensors are made by denso.
Old Jun 12, 2007 | 06:26 AM
powderb18b's Avatar
Default Re: (h8ted ek)
the biggest problem is that my compressor was taken off and sold about 6-7 years ago. does anyone have any good suggestions on one or does it not really matter? i was going to go with a remaned compressor off of ebay? good idea? bad idea?
Old Jun 15, 2007 | 08:00 AM
powderb18b's Avatar
Default Re: (powderb18b)
bump it. LOUDA!
Old Jun 21, 2007 | 07:03 AM
powderb18b's Avatar
if i didnt have the compressor anymore, what compressor do you think i should use? i just need an idea, so i can get a new one and such.
jadugartir
May 25, 2006 08:53 PM
redsled00
Oct 14, 2005 06:39 PM
RCautoworks
24
Jul 25, 2005 03:58 PM
Todapwr
14
Mar 5, 2004 09:49 PM
slowpokesi
17
Jul 20, 2002 08:31 AM
