List your ecu setup in you R
Old Jun 11, 2007 | 07:26 AM
ITR32's Avatar
Default List your ecu setup in you R
I just took out my vafc and was looking to upgrade to a better engine management but have only a few mods. Please list your ecu of choice.b
Old Jun 11, 2007 | 07:42 AM
RedR's Avatar
Default Re: List your ecu setup in you R (ITR32)
running hondata s300 for 1 1/2 years
Old Jun 11, 2007 | 07:43 AM
97CWITR's Avatar
Default Re: List your ecu setup in you R (RedR)
p28 w/crome
itr1244's Avatar
Default Re: List your ecu setup in you R (97CWITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97CWITR &raquo;</TD></TR><TR><TD CLASS="quote">p28 w/crome </TD></TR></TABLE>
X2
Old Jun 11, 2007 | 07:47 AM
nholmes's Avatar
p72 w/ s300
Old Jun 11, 2007 | 08:18 AM
Trellis's Avatar
Virgin
Old Jun 11, 2007 | 09:47 AM
Clerique's Avatar
Is Power FC overkill for an engine with just an exhaust mod and OEM 4-1 header?
Daz what I got!
Old Jun 11, 2007 | 09:53 AM
Trev-R257's Avatar
Default Re: List your ecu setup in you R (Trellis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trellis &raquo;</TD></TR><TR><TD CLASS="quote">Virgin </TD></TR></TABLE>
x2
Old Jun 11, 2007 | 11:13 AM
pennies_hatchie's Avatar
Default Re: List your ecu setup in you R (Trev-R257)
Kpro, oh wait, i have a k20 in my itr. I had hondata s200 with my old setup
Old Jun 11, 2007 | 11:26 AM
neo_'s Avatar
Default Re: List your ecu setup in you R (pennies_hatchie)
I had Crome, but I recently upgraded to Nepune and RTP and will not be going back.
Neptune RTP &gt; Hondata S300
ultimatehonda's Avatar
Old Jun 11, 2007 | 11:48 AM
Spunkster's Avatar
P72 with S300
Old Jun 11, 2007 | 12:30 PM
ej2gsr's Avatar
Default Re: List your ecu setup in you R (ultimatehonda)
x2
Old Jun 12, 2007 | 04:03 AM
Bart-EK's Avatar
just found me a virgin JDM p30 and will be using it with eCtune...
Old Jun 12, 2007 | 04:55 AM
SpdFrk's Avatar
Same here
Old Jun 12, 2007 | 05:42 AM
D-Rob's Avatar
Default Re: List your ecu setup in you R (SpdFrk)
Don't have an R, but I now run the Neptune RTP.
I &lt;3 it.
- Derek
Old Jun 12, 2007 | 06:33 AM
ITR32's Avatar
Default Re: List your ecu setup in you R (D-Rob)
Is neptune and crome easy to program? Is hondata more hype than anything else?
Old Jun 12, 2007 | 12:28 PM
cjames235's Avatar
S300
Old Jun 12, 2007 | 02:43 PM
typeR#0427's Avatar
Default Re: List your ecu setup in you R (cjames235)
JDM P73, but i have a hondata s200, just waiting to find a P28
Old Jun 12, 2007 | 02:44 PM
Seedc2's Avatar
p28 s300
Old Jun 12, 2007 | 08:26 PM
94rs-turbo's Avatar
p28 neptune
Old Jun 12, 2007 | 08:53 PM
cltitus's Avatar
p28 crome & p72 s300
Old Jun 12, 2007 | 08:56 PM
all_motaUSA's Avatar
Default Re: List your ecu setup in you R (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">
X2</TD></TR></TABLE>
x3
Old Jun 13, 2007 | 12:17 AM
blackntegra's Avatar
power fc on boost
Old Jun 13, 2007 | 12:55 AM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR32 &raquo;</TD></TR><TR><TD CLASS="quote">Is neptune and crome easy to program? Is hondata more hype than anything else?</TD></TR></TABLE>
Neptune RTP is equivalent to Hondata S300.
Both are hardware based, real time programmable, and controllable via a USB cable (Neptune RTP even has a Bluetooth add on).
Hondata is not "hype" Hondata was a pioneering force being tunable Honda ECUs. However, now there are better, cheaper, more feature packed alternatives.
You can not compare Crome to Neptune RTP/Hondata S300. Crome is not hardware based, but rather software based. All you need to have is a socketed ODB1 ECU to run Crome, as all the settings are just stored on a EEPROM chip. Hondata/Neptune being hardware based, natively have advantages over Crome and counterparts which can not adhere to. There is no emulating nor chip burning for RTP/S300, so less things that can go wrong, and less stuff to purchase if you are tunning it yourself. Dual map compatibility is present in Neptune/RTP while Crome does not support. Yes, you can buy a 2Timer for Crome and make it work but that just proves the flexibility of RTP/S300. Crome is however free, as all you need is the software. But you will have to buy hardware to tune it. You don't need to buy anything with RTP/S300 to make it work. Comparing S300 vs RTP is prefernce based, but in my opinion RTP wins. RTP just has more features, for example you can manually set the temperate at which your radiator fans turn on so no more need for fan switches, it can be controlled by the ECU. There is no need to jump the service connector plug with RTP, you can just simply hold the gas pedal with the key on at ACC and your CEL will blink the codes. There are tons of these kind of features which RTP has, and S300 lacks. And Neptune just seems to be more solid as a package. Also keep in mind, if you are an end user and do not tune your car yourself then S300/RTP might be overkill for you. Also, you do not need to buy any hardware for Crome as that would be tuner's responsibility when he tunes your car (chip burner, emulator, etc..)
