Suspension & Brakes Theory, alignment, spring rates....
What is the best camber kit for DA integra?
Old Jun 10, 2007 | 10:21 PM
Bro. Darkness's Avatar
Default What is the best camber kit for DA integra?
i just ordered a set of tein s-tech springs and my friend who has the same springs on his DA strongly recommends waiting until i get a camber kit untili lower the car. does anyone know of any high quality camber kits.....skunk2 or omni maybe?
Old Jun 11, 2007 | 12:18 AM
Tyson's Avatar
Default Re: What is the best camber kit for DA integra? (Bro. Darkness)
i strongly recommend you get an alignment after installing the springs and forget the camber kit.
alignments save tires. it fixes the toe. you dont need to change the camber.
Old Jun 11, 2007 | 01:30 PM
Default Re: What is the best camber kit for DA integra? (Tyson)
ok so that will solve the problem after i get my springs but what if down the line im looking to get a camber kit? are there any out there?
Old Jun 11, 2007 | 05:44 PM
Kevin's Avatar
Definetly get the car professionally aligned first and foremost.
My rear lower arm seemed to bind with extreme negative camber in the rear. Im not sure if it was solely the camber or a combination of camber and worn out bushings. I ended up using 10/1.25x50mm grade 8 bolts + 6 10mm washers behind each bolt holding the rear upper arm. I dont want to add anymore washers until i can get the car on a rack and see where its at. Im going to get it re-aligned next week and go from there.
I havent looked into front camber adjustment either but that is next on the agenda, when i find out more i will post back here, unless someone beats me to it.
Old Jun 11, 2007 | 09:56 PM
Default Re: What is the best camber kit for DA integra? (gLok)
thx. any help is greatly appreciated
Old Jun 12, 2007 | 12:03 AM
TEGNO1's Avatar
When you go low enough needing a camber kit on the front what your doing is bringing the control arm further out which might cause it to scrape the side of the inside shock tower.
I dont see any problems in the rear just buy an adjustable from a good company or you will find your bushes destroying themselves pretty quick.
Thats why its a good idea to get the alignment done first and see if you really need them.
Old Aug 12, 2007 | 03:04 AM
ErMaK's Avatar
Default Re: (TEGNO1)
I've got Ingalls on the front and rear and they work great. Really nice quality! I also have Tein S-Techs and Tokico Illuminas.
Old Aug 13, 2007 | 10:07 AM
Default Re: (ErMaK)
what part of SC u in?
Old Aug 13, 2007 | 11:57 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
IMHO unless you race and need to precisely dial in camber, then camber kits are more hassle than it's worth. Get the alignment after installing the suspension and call it a day.
Old Aug 14, 2007 | 05:24 AM
Default Re: (PatrickGSR94)
well i appreciate everyones advice however this thread is pretty old and now i already have my springs on and my wheels, tires, and camber kit are waiting to be put on. btw i got an omni power camber kit and my buddy who works at a tire shop is installing everything and alligning my camber and toe for me. thx for everyone who posted tho.
Old Jan 29, 2008 | 10:30 AM
90JDMCIVIC's Avatar
Default Re: (Bro. Darkness)
will those omni power camber kit from the dc2 fit the da integras???? for the front????
Old Jan 31, 2008 | 07:32 AM
Default Re: (90JDMCIVIC)
yes, mine are for a dc and they fit fine. riding on them since august and no problems yet.
JDM_nUt
Feb 17, 2010 10:33 PM
FLACO EM1
Nov 27, 2008 01:39 PM
allmotorEG-SI
Jun 12, 2003 12:00 PM
93dx--hatch
Feb 19, 2003 10:01 AM
