skunk2 coil question
i got my skunk2 coils yesterday, and they came with a **** load of rubber o-rings and no instructions for suspension install, but came with intake manifold install instructions.. idk, but what are all these o-rings for, honestly theres about 30 of them.
Also, i searched, but what is the adapter part i need from koni to make my koni yellows work with the skunk2 coil-over set.
if you got the skunk 2 sleeve coilovers then the o-rings are suppose to go on the shock to keep the sleeve from moving around...your suppose to find the size that fits best for your car...tahts why they gave you so many
um...you should have that round silver piece...if you do...just get the right size o ring...should only need 2-3 and put it in the shock before that silver piece and then you mount your skunk 2 coilover sleevehttp://img59.photobucket.com/albums/v180/viet83/19_Koni_yellows_with_sportline.jpg
theres the polished silver piece
<a href="http://photobucket.com" target="_blank">
</a
the polished piece you see right there is the one you should have to put your coilovers on...it should go on just like this pic...but make sure your o rings are on
</athe polished piece you see right there is the one you should have to put your coilovers on...it should go on just like this pic...but make sure your o rings are on
BeeSeriesEK4
Jan 4, 2004 09:43 PM
