Fender Turn Signals
Old Jun 10, 2007 | 07:40 PM
honda94accord's Avatar
Default Fender Turn Signals
When wiring up the fender turn signals. I was gonna wire them to the corner lights that flash with the turn signals on the front bumper. I have a 94 accord. I need to kno what color wire up front are positive and negative. Cuz they aren't just black and red there different colors. So does anyone have a wiring diagram for the headlights and corner lights? So i can tell which one is positive and negative.
Old Jun 10, 2007 | 08:34 PM
s_wells's Avatar
use a test light and turn on the blinker when you are testing it you should see it flash that will tell you which one you need.
Old Jun 10, 2007 | 09:57 PM
cb7tougeracer's Avatar
Default Re: (s_wells)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s_wells &raquo;</TD></TR><TR><TD CLASS="quote">use a test light and turn on the blinker when you are testing it you should see it flash that will tell you which one you need.
X2
Old Jun 11, 2007 | 06:47 PM
Default Re: (cb7tougeracer)
Ok but how do i kno which one is the hot one from the battery? And which one is the ground? Or does it matter?
Old Jun 12, 2007 | 04:27 AM
TheMuffinMan's Avatar
He knows where you live!
or don't listen to them?
if you're not sure use a multimeter or a bulb to test with
EKwillister
Lighting
Oct 23, 2008 02:00 PM
hmgemperor2003
Feb 18, 2007 05:53 PM
b20eg6hatch
Mar 21, 2006 07:08 PM
sTraNdeD
11
May 9, 2004 04:00 PM
