Loose steering. PIC
Old Jun 10, 2007 | 05:58 PM
na4now's Avatar
Default Loose steering. PIC
I bought a 93 hatch today, and the sterring felt squirrelly, and shakes on the highway.
I jacked it up and looked at it, and the ball and socket, where the tie-rod goes into the steering rack, is wore out. Can I replace this joint, or will I have to change the whole rack?
Old Jun 10, 2007 | 05:59 PM
na4now's Avatar
Default Re: Loose steering. PIC (na4now)
I slid the boot back, btw.
Old Jun 10, 2007 | 06:15 PM
t0p_sh0tta's Avatar
#1 (I think, the pic sucks), inner tie rod. $40 @ HondaAutomotiveParts.com
Old Jun 10, 2007 | 06:27 PM
cimo463's Avatar
the shaking steering wheel sounds like out of balanced tires
Old Jun 10, 2007 | 06:29 PM
t0p_sh0tta's Avatar
Default Re: Loose steering. PIC (cimo463)
It can also be due to worn suspension components. Cupping of the tires is also indicative of various suspension issues (worn struts, worn balljoints, etc.).
Old Jun 10, 2007 | 06:33 PM
na4now's Avatar
Tires might be out of balance. The inner part of the tire is worn, also. Im sure this is because this tie rod is so loose.
How do you remove this piece? How does it come off?
Old Jun 10, 2007 | 06:53 PM
sniggler316's Avatar
You need a REALLY big wrench. It's easier if you drop the rack IMO
Old Jun 10, 2007 | 07:04 PM
na4now's Avatar
Default Re: Loose steering. PIC (sniggler316)
What do you replace? The whole thing (in green)? Does the deal circled in red, unscrew?
Old Jun 10, 2007 | 07:38 PM
92ehatch's Avatar
grab your wheel at 9 and 3 and shake.
does it wobble?
if so look at the joint you have circled. does it move when you shake the wheel?
if so then thats the problem. if not then its not causing your issue.
use that same method for the balljoint on the outer tie rod (close to the rotor)
now do the same thing but with your hands at 12 and 6.
if it wobbles then watch the upper balljoint and lower balljoint on the upper and lower control arms.
if they dont move when you do that, but the wheel wobbles when using the 12 and 6 method, then it is most likely a wheel bearing.
i hope that makes sense..
crown and coke ftw
Old Jun 10, 2007 | 08:24 PM
na4now's Avatar
Default Re: Loose steering. PIC (92ehatch)
Of course it wobbles. Thats the whole reason for posting this, with pictures. I need to no how it comes off, and which piece/pieces to replace.
Old Jun 10, 2007 | 10:03 PM
na4now's Avatar
This is what new inner tie rods look like. They dont look the same. Are they?
Old Jun 10, 2007 | 10:10 PM
DaZDiLI's Avatar
you should go get an Alignment first to see if that solves your probelem.
Old Jun 10, 2007 | 10:47 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (DaZDiLI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaZDiLI &raquo;</TD></TR><TR><TD CLASS="quote">you should go get an Alignment first to see if that solves your probelem.</TD></TR></TABLE>
And how exactly would YOU go about aligning a car with a trashed tie rod?
Old Jun 10, 2007 | 11:10 PM
na4now's Avatar
Default Re: (oneludesol)
You cant. You have to fix the broken part, first. Anyone know exactly how the inner tie rod, comes off the rack?
Old Jun 11, 2007 | 04:46 AM
t0p_sh0tta's Avatar
Default Re: (na4now)
There's a special socket that's used to remove it. Somebody mentioned something about a BIG wrench, which might work, but I've never done it that way.
Old Jun 11, 2007 | 05:45 AM
Default Re: (t0p_sh0tta)
I used a giant wrench to unscrew mine, I didn't know about that special socket. Mine had two flat sides where I could get a wrench on it. They just trun out clockwise like anything else.
Old Jun 11, 2007 | 07:08 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
LOL DUH I was being sarcastic
Old Jun 11, 2007 | 11:50 AM
na4now's Avatar
I oredered these exact ones, offf ebay. Does this look correct? They look different to me.
Old Jun 11, 2007 | 11:59 AM
Those are what you need. While you are in there, I would check all the other ball joints and tie rod ends. Might even want to do the axles if they haven't been replaced.
Old Jun 11, 2007 | 12:08 PM
na4now's Avatar
Default Re: (sniggler316)
Thanks. Everything else looks real good.
The last time I had this problem, I just changed the whole rack! What a bitch! Had to drop the exhaust and shift linkage. This should be alot easier.
Old Jun 11, 2007 | 12:17 PM
na4now's Avatar
Any idea what size wrench that is? I dont need to put a wrench on the steering rack side?
Old Jun 11, 2007 | 12:59 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
you need to grab a tie rod end tool... dont you fuking dare go near that with a wrench
Old Jun 11, 2007 | 01:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by na4now &raquo;</TD></TR><TR><TD CLASS="quote">Any idea what size wrench that is? I dont need to put a wrench on the steering rack side?</TD></TR></TABLE>
I dunno, I used a big crescent. The rack side I think is 21?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol &raquo;</TD></TR><TR><TD CLASS="quote">you need to grab a tie rod end tool... dont you fuking dare go near that with a wrench
Why not?
Old Jun 11, 2007 | 01:48 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
It is alot easier to get loan a tool from discount, than rounding that **** off and spending the rest of your life trying to remove it... that thing needs to be held all the way around, and they are usually tight as ****. You got lucky with the wrench.
Old Jun 11, 2007 | 01:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol &raquo;</TD></TR><TR><TD CLASS="quote">It is alot easier to get loan a tool from discount, than rounding that **** off and spending the rest of your life trying to remove it... that thing needs to be held all the way around, and they are usually tight as ****. You got lucky with the wrench.</TD></TR></TABLE>
I guess I'm "lucky," I don't see how you can round those off, but if you can find someplace to loan you the tool, then by all means, go that route. That tool is probably expensive as **** to buy though...
