springs
Old Jun 10, 2007 | 02:36 PM
ef9ontime's Avatar
Default springs
Recently I swapped a b16 into my 91 si. Ever since the added weight(b series), I had to adjust my front suspension. I am currently running h&r sport springs, and koni yellows. The fronts are all the way up(highest setting), and there is like 1 inch gap between fender well, and top of tire. The rear is set all the way down (lowest perch), and the car sits even. My question is, does H&R make a spring for a b16 hatch? My car rides decent, but Im thinking I need stiffer springs in the front. BTW, I took this setup off of my crx, does that make any difference as well??
Old Jun 10, 2007 | 10:30 PM
mahatma's Avatar
Default Re: springs (ef9ontime)
it's good if the car sits even.
crx/civic are the same parts
....the car doesn't handle to your liking or....? what's the problem?
Old Jun 12, 2007 | 06:39 AM
ef9ontime's Avatar
Default Re: springs (mahatma)
The front springs cant handle the b series. I am looking for a good spring that will be a little stiffer, but not a race spring(the car is a daily driver). I have the front on the highest perch setting, and there is 1 inch gap between top of tire, and fender. The rear is on the LOWEST setting, and the car sits even.... BTW I am running H&R sport springs. Anyone know how progress springs are because they make a spring specifically for a b series in a ef?
Old Jun 14, 2007 | 08:57 PM
ef9ontime's Avatar
no one can answer my question huh?
Old Jun 14, 2007 | 08:59 PM
horsekiller's Avatar
progress offers a set up for 88-91 civic/crx with bseries. 2" drop front and rear.
092eg6
Suspension & Brakes
Sep 8, 2010 07:26 PM
coot_er
Suspension & Brakes
Jan 19, 2009 05:08 AM
ef9ontime
12
May 4, 2007 05:20 PM
x91crxsix
May 31, 2006 04:23 PM
TurboEM1
Suspension & Brakes
Mar 20, 2006 05:57 AM
