Those with C&R radiator, what fan are you guys running for NA setup?
Old Jun 10, 2007 | 11:45 AM
VSBB6's Avatar
Default Those with C&R radiator, what fan are you guys running for NA setup?
The single 14" SPAL fan that came with my C&R radiator finally gave up and keeps blowing my fuse, so I'm looking to replace/upgrade to dual fan setup to optimize the cooling system.
The C&R measure 27" x 17", it's rather thick and leaves only about 2" gap in between the engine mount and the aluminum core on one side for a slim fan to fit. The other side is rather roomy and could accomodate a thicker fan.
Those of you running C&R, have you upgraded your fans? If so, what are you running?
I'm very interested in the dual Flex-A-Lite (FAL) fan for integra, but I'm not sure if there's enough clearance to fit.
If clearance is the issue, I can always settle for dual 10" or 12" slim fan setup.
Cheers.
Old Jun 10, 2007 | 12:13 PM
Hawkze_2.3's Avatar
Default Re: Those with C&R radiator, what fan are you guys running for NA setup? (VSBB6)
I'd just get 1 or 2 generic slim fans...you should be fine with that especially on an NA setup. I just have one 12" slim fan and a 1/2 radiator with no problems.
g2turbo
Oct 16, 2009 07:36 PM
Rah Rah
Aug 4, 2003 09:00 PM
Etylorcen
Aug 2, 2002 10:35 PM
