96 EK D16Y8 shuts off when I turn on A/C
Old Jun 10, 2007 | 11:42 AM
stockCRXsi's Avatar
Default 96 EK D16Y8 shuts off when I turn on A/C
I know that in the Z6 there is a purge valve that shoot the idle up when you turn on the A/C.
what controls the idle when I turn on the AC in my EK?
my cars' idle drops to about 400 to 500 when I turn on the A/C and comes back to normal when I turn the A/C off.
thanks for the help
AICV works properly and the only cel I have is KNOCK sensor.
Old Jun 10, 2007 | 01:07 PM
EJ8CIVIC's Avatar
Default Re: 96 EK D16Y8 shuts off when I turn on A/C (stockCRXsi)
lol i got the same problem and i like to know also
my car is 98 exd16y8 (181056 miles on it)
Old Jun 13, 2007 | 04:52 PM
stockCRXsi's Avatar
ant ideas?
Old Jun 13, 2007 | 06:18 PM
hondamark35's Avatar
some ideas yes... the answer for you, i'll let you be the judge.
i know if the a/c has too much freon it'll load the engine down too much when you turn it on.
i would also look to see if the compressor fan comes on when you cut the a/c on. don't know if that would make the idle that low but it will also cause more load on the system.
turn all your electrical accesories on, headlights, blower motor, sterio and see if the idle drops then. if so the problem is with your idle system
Old Jun 15, 2007 | 05:17 PM
stockCRXsi's Avatar
turned on all electronics and idle did drop. It actually drops as soon as I turn on headlights on high beam. so I guess ILL be doing some hard research on the idle control system.
thanks for the input
Jimi Hondrix
11
Apr 19, 2016 03:44 PM
01nhbgsr
Aug 29, 2007 11:34 PM
ithrowpoop
Nov 21, 2006 06:58 PM
Slammed Ek9
Apr 7, 2005 03:00 PM
Mr.Integra
Jul 27, 2003 12:14 PM
