main relay is good, still no power to fuel pump
I check all the fues, main relay, they are good, I still can't get any power to the fuel pump, also when I spray starting fuild in the air intake, it will not try to start. If any one has any ideas, I would be greatly apreciated. Thankyou
had this same problem going on with my hatch about a month ago, it had fuel and spark (but not a strong spark), it ended up being the ICM. Take apart your dizzy and check the inner components.
Was your car in an accident recently? Because honda's have a safety switch wich disconnects the main powersupply to the fuel pump. The switch activates when the front of your car hits something. Maybe that's it.
I did what the shop manual told me, I have a click and a continuity, pulled the fuel pump out, and put power to it, and it does not turn on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luv2xlr8_1989 »</TD></TR><TR><TD CLASS="quote">Was your car in an accident recently? Because honda's have a safety switch wich disconnects the main powersupply to the fuel pump. The switch activates when the front of your car hits something. Maybe that's it. </TD></TR></TABLE>
not true i know some american cars have that feature but as far as acura and honda go no dice.
Please explain, becuse i'm not used to these newer engines. If u know were I could get a complete layout of the engine, and the discrption were the parts are. That will be a big help.
As far as I know that it never was, been in the brush row for a few years, I dont know anything about a kill switch. I'm not used to these newer cars with an EIC.
http://techauto.tripod.com/mainrelay.htm look through this site it has some great info
i can hear a click in the main relay for about 3 seconds when the key is turn on. I put a light tester on the fuel pump relay, does not turn on, when key is turn on.
no voltage to pump, there is oil around spark plugs (4), can just drain the oil and try to start it with starting fluid, please help me get this running so i know if i should try and get the title for it. Thank you
so is a fuel problem? if your not sure disconnect fuel line from the injector rail, turn the key on and see if you have a fuel squirt out, unless you have a gauge to test. If pump is working. Pull on of your spark plug wires out and hold it close to a bolt on your valve cover and see if you have spark jump the gap. if not replace your ignition coil! If neither work for you, switch to a know good ecu!
i could give you a million tests to perform, but with the info you have provided... not much i can do.
as mitch hedberg said " i would be a shitty auto mechanic, i would have a customer come to me and say, "my car won't start!" and then i would reply " MAYBE THERE IS A KILLER AFTER YOU! ""
I was at the junk yard, and didn't find a honda wagon, so i would like to know what fuel pumps are interchangable. Thank you
