swapping motor need help
Old Jun 9, 2007 | 11:14 PM
boosted111EG's Avatar
Default swapping motor need help
whats up, im doin a swap i read the posts at the top but im useing alot of different parts. i have a 1995 honda civic dx, i am putting a b18a engine with gsr s80 hydraulic tranny, which mounts do i use where? and what half shaft/axles do i use because the one that came with the motor doesnt seem to fit with the tranny? if anyone can help please and thank you, i have pics will post later
Old Jun 10, 2007 | 12:42 AM
CapnKrunch's Avatar
Default Re: swapping motor need help (boosted111EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted111EG &raquo;</TD></TR><TR><TD CLASS="quote">whats up, im doin a swap i read the posts at the top but im useing alot of different parts. i have a 1995 honda civic dx, i am putting a b18a engine with gsr s80 hydraulic tranny, which mounts do i use where? and what half shaft/axles do i use because the one that came with the motor doesnt seem to fit with the tranny? if anyone can help please and thank you, i have pics will post later</TD></TR></TABLE>
The ones that came with the motor are for the cable tranny so you need axles from a 94-01 integra w/ a Hydro tranny any hydro B series axles should work.
Old Jun 10, 2007 | 06:50 AM
crazyguy's Avatar
u are going to need the new motor mouts for b series into your civic
and also u will need b series half shaft, and b series axles..
u can use dc integra half shaft and axles too..for the drive axles.u can get those remanufacture ones from auto zone..they are almost as good as brand new for like under 65 bucks a piece with exchange of your old ones.
Old Jun 10, 2007 | 07:31 AM
Default Re: swapping motor need help (crazyguy)
thanks guys, but can i use the mounts that came with the b18a engine from a 92 integra?
Old Jun 10, 2007 | 04:22 PM
bump need more help
the rear mount that came with the motor fits, but the one above the timing belt does not, am i doing something wrong or am i using the wrong mounts the wrong ones, b18a in 95 civ,
Modified by boosted111EG at 6:30 PM 6/10/2007
Old Jun 10, 2007 | 04:28 PM
abusedhusband's Avatar
you can use the stock engine mounts from the 95 civic. you need the rear t bracket and driver metal munt that bolts to the block from a 94-01 integra. u will need a manual trans half shaft from a 90-01 integra. 90-93 uses a different axle than 94-01 tho. make sure you know what halfshaft you get. the pass side axles are the same from 90-01.
Old Jun 11, 2007 | 06:24 PM
Default Re: swapping motor need help (abusedhusband)
bump
one more question, it seems like everything is lined up, but when the top tranny mount is connected the front tranny mount wont line up and the same with that mount.. so now are one of the mounts the wrong ones, they should be both from 94-up gsr tranny mounts.
spens 91 Ef
Jul 14, 2010 06:15 PM
93baggedcivic
May 6, 2007 11:41 AM
god.loves.ugly
Oct 31, 2005 08:14 PM
rocco
Dec 3, 2003 07:42 PM
