Hub Assembly swap
So i just bought a 4th gen accord. Terrible vibration when i brake. I then realized i have pressed rotors
boo hiss. Anyone know how much of a pain it would be (or if its even possible) to swap over to a floating rotor assembly? If i'm not mistaken 5th gen v6s are floating. Are the splines on the drive shafts the same?
Is there some boon I'm missing with the pressed rotors? I hate servicing them, myself.
boo hiss. Anyone know how much of a pain it would be (or if its even possible) to swap over to a floating rotor assembly? If i'm not mistaken 5th gen v6s are floating. Are the splines on the drive shafts the same?Is there some boon I'm missing with the pressed rotors? I hate servicing them, myself.
The deal current brake setup, I believe is called, Hub over Rotor. It isn't press in. Just hard to take out. What you want to convert to is Rotor over Hub. Check the Accord FAQ. Anyways even the 5th gen Accord V6 still uses hub over rotor. (Not completely sure though)
TypeSH
Jun 29, 2003 06:23 PM
