f20b head on f23a1
Old Jun 9, 2007 | 07:30 PM
wzachmorris's Avatar
Default f20b head on f23a1
is there any reason why you couldnt put an f20b dohc vtec head on a f23a1 block? i searched all over here and i didnt see anybody else ask that question so im just wondering why it wouldnt work? any ideas thoughts testimonials would be great
Old Jun 9, 2007 | 08:19 PM
jweller's Avatar
Default Re: f20b head on f23a1 (wzachmorris)
If I recall correctly the f20b head is pretty much the same as the h22 head. If thats right, then yes its a pretty straight forward swap
Old Jun 10, 2007 | 01:00 PM
Default Re: f20b head on f23a1 (jweller)
i knew that. what i was wondering is if anyone had done it. Because the way i see it f20 b has supposedly a good r/s ratio and if you put that head on the f23a1 then it would lower compression and there fore make a nasty *** turbo setup that could make power up to 8500 rpms. right?
Old Jun 10, 2007 | 06:16 PM
jweller's Avatar
teh r/s ratio of the f20b is irrelevant if you are using the f23 bottom end.
I wouldn't spin a f23 bottom to 85 unless I built it up
Kountryboy8750
Feb 6, 2011 12:43 PM
wildstyle554
Mar 26, 2009 08:04 AM
digital sol
Feb 1, 2005 07:58 AM
tsjag17
Jul 22, 2001 08:24 PM
