f22 turbo
Old Jun 9, 2007 | 06:08 PM
ryanmcdermit's Avatar
Default f22 turbo
can you stay with stock injectors after turboing a f22?
Old Jun 9, 2007 | 06:16 PM
mattsnooz's Avatar
Default Re: f22 turbo (ryanmcdermit)
whats your boost expectation? like 10 or so?
Old Jun 9, 2007 | 06:41 PM
ECX's Avatar
ECX
* B A N N E D *
Default Re: f22 turbo (mattsnooz)
Depends on the setup. Probably not.
Old Jun 9, 2007 | 07:26 PM
i was gonna run it around 7 or 8 psi
Old Jun 9, 2007 | 07:54 PM
BrockNB's Avatar
No, you will need to upgrade your injectors. I would advise on nothing smaller than 440cc. Also you will need peak and hold injectors because you have an injector resistor box.
Old Jun 9, 2007 | 08:41 PM
ECX's Avatar
ECX
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryanmcdermit &raquo;</TD></TR><TR><TD CLASS="quote">i was gonna run it around 7 or 8 psi</TD></TR></TABLE>
What turbo are you looking at using? Flow characteristics change with different turbochargers... bigger or smaller will affect how much airflow you have at a certain psi, say 7 psi out of turboX will be different that 7 psi out of turboY.
chrisfromsrq
Oct 4, 2009 04:19 PM
B18 rider
Aug 8, 2008 10:51 AM
nicko360
12
Mar 6, 2007 12:33 PM
menappi
11
Mar 25, 2005 12:25 PM
The DX Rex
Dec 28, 2004 07:25 PM
