CRX Manual Transmission Fluid Level
Old Jun 9, 2007 | 05:13 PM
urkcrx's Avatar
Default CRX Manual Transmission Fluid Level
Had my CRX up on ramps for the change. Seemed like more than 0.1 qts ran out after I pulled the fill hose. Does the angle on the ramps make a huge difference? Once I got it off the ramps I felt inside the fill level hole and it felt a bit low.
Any thoughts/input? Should I be worried?
Thanks.
Old Jun 9, 2007 | 05:16 PM
danmdevries's Avatar
Default Re: CRX Manual Transmission Fluid Level (urkcrx)
Put it on the ground, throw a jack under on the pass side, pop the wheel off and pull the plug. If it's not up to the bottom of the hole, put some more in. If it flows out, let it drain until it's level with that fill hole.
I think depending on the height of the ramps it will make a difference.
Old Jun 9, 2007 | 08:18 PM
Crx Jimmy's Avatar
it should be filled on a level surface. I would check and add some more if needed
Old Jun 11, 2007 | 04:28 PM
urkcrx's Avatar
Default Re: CRX Manual Transmission Fluid Level (Crx Jimmy)
Yep, had to add about 200ml or .2 quarts once it was level. Not sure how much difference it would have made but BSTS.
Thanks for the help.
KyonMechburg
Jun 27, 2018 08:36 PM
Rhymesayer
Feb 19, 2015 11:15 AM
Integra9000
May 24, 2007 10:51 AM
Y2KGreenGSR
Sep 28, 2001 12:11 PM
