broke master cylinder mounting stud... replaceable?
ok i over tightened my master cylinder mounting nut and broke the stud, the one that sticks out of the master power unit (brake booster i believe). i was wondering if it is possible to replace the stud/bolt without taking the whole booster apart? i was looking at the diagram on hondaautomotiveparts.com and i know i cant buy the stud seperatly so i'm gonna have to salvage it from the wreckers. oh and the stud broke off to where i can no longer tread a nut on it. anyone have a writeup or suggestions on what to do? i searched and couldnt find anything.
i really hope i dont have to replace the whole brake booster.
I think the stud is part of the booster, not just screwed into it. I'm not certain though. I'd say it sounds like its time to get a bigger booster.
you can replace the studs - you have to disassemble the booster to do it, but the studs run all the way through the housing with threads on both ends - it has nuts and washers on the back side of the housing
thanks for the help, i just ended up replacing the whole brake booster. i picked one up from the auto wreckers for $20 and put it in. was a biatch to get the old one off my car with the dash and steering column in, but it all worked out fine.
thanks for the help
thanks for the help
DC5_lov3r
Apr 16, 2008 07:28 PM
integra123
Aug 8, 2006 05:52 PM
92integraVTECgsr
Oct 26, 2005 05:17 PM
