gas smell in my EF HATCH
Old Jun 9, 2007 | 01:08 PM
EFLS89's Avatar
Default gas smell in my EF HATCH
ok, i just bought a EF hatch SI and the seller said that it would need a new gastank , so i bought a new one and had it installed, but for some odd reason i still smell gas fumes, i need to figure out what is cuasing the smell, any clue on what it might be?
Old Jun 9, 2007 | 01:40 PM
hondacrxturboSi's Avatar
Default Re: gas smell in my EF HATCH (EFLS89)
the gasket could be fixed but the smell still there and reason why is gas is a hard smell to get away or maybe you didnt fix the problem.did u check the fuel lines going into the fuel filter...or see if the injectors aew leaking
Old Jun 9, 2007 | 04:15 PM
ef_88_hatch's Avatar
i hade the same problem i had to clean out the vent tub and dont top off the gas tank when you fill it up. i dont have any problems now. hope it helps
Old Jun 9, 2007 | 05:20 PM
danmdevries's Avatar
Default Re: gas smell in my EF HATCH (ef_88_hatch)
Because of a water leak in my crx, the fuel return line rusted and sprung a leak underneath the carpet. It was only a pinhole and hard to find, but once I had the carpet out I found it.
Old Jun 9, 2007 | 05:55 PM
white ef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_88_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i hade the same problem i had to clean out the vent tub and dont top off the gas tank when you fill it up. i dont have any problems now. hope it helps</TD></TR></TABLE>
whenever i fill up my ef, i put 9 gal in it, instead of 10. that way i dont smell gas.
Old Jun 9, 2007 | 09:00 PM
rexracerboy's Avatar
Default Re: gas smell in my EF HATCH (white ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">whenever i fill up my ef, i put 9 gal in it, instead of 10. that way i dont smell gas.</TD></TR></TABLE>
OMG
haha that's funny.
Old Jun 10, 2007 | 05:11 AM
Chiovnidca's Avatar
Default Re: gas smell in my EF HATCH (danmdevries)
I've seen a few rusted fuel lines under the carpet at the front of the left rocker panel.
Old Jun 10, 2007 | 05:21 PM
EFLS89's Avatar
Default Re: gas smell in my EF HATCH (hondacrxturboSi)
ok ill be sure to check it out soon ill let u guyz know on the update thanks much
Old Jun 10, 2007 | 05:56 PM
dohc_profile's Avatar
maybe fumes coming up through shift boot. se if theres any exhaust leaks
Old Jun 10, 2007 | 06:00 PM
EF_LSVtec's Avatar
Default Re: (sohc_mnstr)
Or you can try putting a banana in a bag and leave it in your car...after a few days it'll rot and stink so pretty soon you won't notice the smell of gas I'm kidding...I hope you find the culprit and fix it quick. Don't you get dizzy having to sniff that while driving too?
Old Jun 11, 2007 | 06:38 PM
EFLS89's Avatar
Default Re: (EF_LSVtec)
hahaha, nice
I've adapted to the smell by now, but people complain when I give them a run in the car
Siabraham1990
Dec 10, 2017 07:32 PM
sh_or_ty
May 8, 2010 12:00 PM
VRD^don
Jan 24, 2007 09:01 AM
Power Rev Racing
47
Aug 19, 2005 03:23 AM
goforbroke
Aug 6, 2004 06:15 AM
