Ghetto rocker switch (from pep boys) not lighting up when fogs are on???
Not sure which forum to post this on... sorry!
I am thinking maybe it's a bad switch I bought... but wanted to ask for someone's expertise before i go buy another one:
I have my jdm fogs wired to the rocker switch. Yes, it may be ghetto..but i didn't want the fog light switch where the cruise control is supposed to be a la JDM fog light switch. Instead, I wanted the switch to be near the ebrake --- and I would get the USDM fog light switch but there are so many prongs on the back i dont know which 3 are the ones I need to hook up to the relay, ground, and acc.
Currently, my fogs are connect to a relay. The illuminated rocker switch I have has 3 prongs: Power, Ground, Acc.
The Power i have a wire that goes to the relay.
The Ground is grounded (duh).
The Acc is connected to my parking lights (so the fogs will only turn on/off if the parking lights are on).
Is this setup right? Supposedly if the fogs are on, the rocker switch should light up as well right? Mine's not lighting up!
SigmaOmega
Jul 17, 2005 06:55 PM
