Skunk 2 Pro 1 vs ITR cam test!
Old Jun 9, 2007 | 07:30 AM
tony1's Avatar
Default Skunk 2 Pro 1 vs ITR cam test!
Hey guys, finally got a tranny in the car that won't fall apart on the dyno and got a chance to do some cam testing. This was on the red integra. We were running ITR cams all last year and wanted to try the Skunk 2 Pro 1 cams.
This dyno was with the boost controller settings identical. When you get an engine to breathe better, power goes up, and boost goes down, because there's not as much restriction on the intake side. That being said, pay attention to the boost curves between both runs. Unfortunately, the Motec windows intrepreter isn't opening the DOS logs correctly, so the only way i know to show the logs is with a pic. You can see that the boost went down quite a bit it high rpm with the S2 cams, and power was still above the ITR cams by quite a bit.
Also, i didn't bring the boost on as hard as i could have because it was spinning the tires, so i had to gradually ramp it up. This was done the same on both runs though.
I think i'm going to have to give the Pro 1's
ITR cam boost plot (who's that sexy bald guy?)
340kpa = ~35psi
S2 Pro boost plot
317kpa = ~ 31.5psi
Old Jun 9, 2007 | 07:34 AM
SovXietday's Avatar
Default Re: Skunk 2 Pro 1 vs ITR cam test! (tony1)
Very nice, 42whp increase.
Old Jun 9, 2007 | 07:38 AM
Ubertec's Avatar
Alot more air with less boost, nice test man!
Old Jun 9, 2007 | 07:39 AM
Hondatron's Avatar
36.6 hp just from changing cams is a great investment! with almost 5 psi less boost too !
thanks for the writeup!
42whp? not in my math your abacus is malfunctioning (edit) i see what your adding nm
Old Jun 9, 2007 | 07:46 AM
turbodohcsi's Avatar
Is this with everything set at tdc? stock, or oversized valves?
oh yeah, and what turbo?
Old Jun 9, 2007 | 07:49 AM
tony1's Avatar
Default Re: (turbodohcsi)
1.5mm OS intake valves, and 1mm over exhaust. S2 cams ended up at +2 intake +2 exhaust. ITR cams ended up at 0 intake, -2 exhaust
GT4294 turbo, Full Race divided top mount manifold, 84x89mm motor, edelbrock intake manifold, 74mm t/b, T1 ic, 4" dp and ex.
Old Jun 9, 2007 | 07:52 AM
damn, i got worried about running 1mm oversized intake and exhaust.
Are your pistons are custom cut? what c/r?
to be honest im trying to see if i can get away with these and my vavles on my stock shelf 85mm 9.7:1 c/r cp pistons.
Old Jun 9, 2007 | 08:05 AM
wade's Avatar
nice to see. why are you not in St.Looey!
Old Jun 9, 2007 | 08:10 AM
SovXietday's Avatar
Default Re: Skunk 2 Pro 1 vs ITR cam test! (Hondatron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondatron &raquo;</TD></TR><TR><TD CLASS="quote">36.6 hp just from changing cams is a great investment! with almost 5 psi less boost too !
42whp? not in my math your abacus is malfunctioning (edit) i see what your adding nm </TD></TR></TABLE>
Whoops I read from the points labled on the graph not peaks.
Abacus is fine... it's my brain that malfunctioned.
Old Jun 9, 2007 | 08:13 AM
tony1's Avatar
Default Re: Skunk 2 Pro 1 vs ITR cam test! (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">nice to see. why are you not in St.Looey!</TD></TR></TABLE>
The car and Chuck are on their way there. I'm at home playing daddy.
Old Jun 9, 2007 | 10:20 AM
*Boostwerks*'s Avatar
SWEET. I was waiting to see you test those out. Looks like a great gain to me.
More area under the curve...less boost...lower Iat's... hell yeah!
I just wonder how the Pro 2's would compare...
Old Jun 9, 2007 | 10:28 AM
RedR's Avatar
Default Re: (Boostwerks.com)
wow nice gains!
Would you consider those worth the investment for a 300-400 whp setup?
Old Jun 9, 2007 | 10:31 AM
tony1's Avatar
Default Re: (RedR)
Cam selection has a lot to do with exhaust manifold and turbo combination. With a good breathing setup, i think they would be benficial. With a small turbo and/or cast style manifold, probably not so much.
Old Jun 9, 2007 | 10:36 AM
Tornadom's Avatar
Wow! That is really all I can say.
Great numbers, great car, great guy.
Old Jun 9, 2007 | 10:50 AM
tepid1's Avatar
Default Re: (tony1)
Tony, what year ITR cams were you using?
Old Jun 9, 2007 | 11:32 AM
OceanStateTuning's Avatar
Default Re: (tepid1)
Now do a compare to the Mazworx
Old Jun 9, 2007 | 11:59 AM
tony1's Avatar
Those were 2000 ITR cams
Old Jun 9, 2007 | 12:01 PM
PrecisionH23a's Avatar
Myspace picture ftw baldylocks!
Good info tony... I've been wanting to see some pro1 feedback. My buddy Greg was over at Skunk2 last month and spoke with Tony over there about using them on his application and seeing how they would do compared to his GSR's. Looks like I don't need to do any testing now, lol.
tony1's Avatar
Default Re: (OceanStateTuning)
Send me some Mazworx and some money for my time and i'll do a back to back with them...
Old Jun 9, 2007 | 12:26 PM
still_slow's Avatar
I was talking to skunk2 about those cams and what I was told by them was that they have seen 80-100HP increase with just the cam upgrade on boosted cars after 400hp.what you just posted backs that up 100% glad to see it I know my next investment
Old Jun 9, 2007 | 02:56 PM
a1320addict's Avatar
Default Re: (still_slow)
Old Jun 9, 2007 | 03:26 PM
uglyasscivic's Avatar
Default Re: (a1320addict)
Good test Tony. I saw about the same gains changing from the ITR cams to the JUN 2's. I imagine the Skunk Pro1's are A LOT cheaper then the JUN cams though.
What are the gains you saw between the 1.01 and the 1.28 rear housing?
Old Jun 9, 2007 | 04:58 PM
Hondatron's Avatar
Default Re: (uglyasscivic)
do you think reg skunk2 stage 2 would have the same affect they have more duration and less lift? they are one of the all motor "wonder cams" too
Modified by Hondatron at 9:39 PM 6/9/2007
Old Jun 9, 2007 | 06:11 PM
mini-cRx's Avatar
nice
Old Jun 9, 2007 | 06:47 PM
GodFather of Boost's Avatar
Default Re: Skunk 2 Pro 1 vs ITR cam test! (mini-cRx)
what about the valvetrain? 12+mm lift+10k rpm+35lbs+wrong valvetrain=pile of scrap metal. I think this is what may have happen to my white car.
