Clutch pedal return problem
Old Jun 9, 2007 | 06:41 AM
gulfview's Avatar
Default Clutch pedal return problem
Yesterday, while on the street, my clutch pedal would not return from the floor, until I pulled it back with my left foot. Now it seems okay, although it returns a bit slowly once in a while.
There is no obstruction down on the floor and the small V-shaped return spring down by the pedal is in place.
Based on your experience, what could the problem be?
Modified by gulfview at 1:19 PM 6/9/2007
Old Jun 9, 2007 | 09:19 AM
FarinaMotorsports's Avatar
Default Re: Clutch pedal return problem (gulfview)
It sounds like your master or slave cylinder is going bad. Have you checked the fluid reservoir level. If it's low check the master and slave for leaks. Whichever is leaking replace it.
Old Jun 9, 2007 | 10:57 AM
hondadude's Avatar
Go dash diving and look where the clutch pushrod enters the Clutch master, if there are fluid drips there replace the master.
Old Jun 9, 2007 | 03:18 PM
jabontke's Avatar
Default Re: Clutch pedal return problem (hondadude)
just for kicks, look and see if the spring connecting the pedal under the dash is broken, too.
Old Jun 9, 2007 | 04:47 PM
JDM_DC4_Fanatic's Avatar
Default Re: Clutch pedal return problem (jabontke)
sounds like either a toasted clutch disc, or air in the lines.
Old Jun 9, 2007 | 08:34 PM
soon2bdropped's Avatar
Default Re: Clutch pedal return problem (JDM_DC4_Fanatic)
wanna explain how a toasted disc would act like that?
Old Jun 9, 2007 | 10:50 PM
gulfview's Avatar
Default Re: Clutch pedal return problem (soon2bdropped)
Thanks, guys!
Old Jun 10, 2007 | 08:00 AM
when the clutch disc is work out, 99% of the time the pressure plate fingers are work out as well, as they usuially go at the same time. So, if theres no pressure on the fingers, the release bearing will not be pushed back by them, and the slave wont return, and that will keep the pedel on the floor.
ducsaim
Jan 14, 2011 12:17 AM
hannslebo
Mar 24, 2009 01:53 PM
garyc17
Dec 18, 2006 10:24 AM
nsimov
Nov 28, 2005 08:04 PM
Turbo D17
Oct 20, 2004 03:28 PM
