ITR stalls won't start for 2 minutes then runs fine again
Old Jun 9, 2007 | 05:05 AM
Whynam's Avatar
Default ITR stalls won't start for 2 minutes then runs fine again
Here's the problem...
-I start my car thats been off for a few hours
-I drive for about a block
-My car stalls and won't start for at least 2 minutes
-Once I get it to start the car runs perfectly fine
No CEL or any other warnings when the car is running.
In the morning I warmed up the engine before I drove it and I didn't have this problem. I encountered this problem in the afternoon and in the late evening. These were all daily driving situations.
I did quite a search through the Integra section and ITR section. It took me a while to figure out to use the "search through archive button". There are so many situations that weren't quite the same.
I really hope the situation is similar to this one
http://www.s2ki.com/forums/ind...=idle
Coles notes of above: ECU is adjusting to climate/temperatutre/altitude and it's normal. If this scenario is applicable to ITRs then note that my car was in a higher altitude city but now it's in a city thats at or even below sea level. The weather also hasn't been consitant.
I'm a noob but any type of help would be greatly appreciated. I really love my car I hope it's nothing too serious. My uncle is a mechanic and I plan to take it to his shop when I can. Any piece of mind till then would help!
Old Jun 9, 2007 | 08:04 AM
Mr. Carbon Fiber's Avatar
Default Re: ITR stalls won't start for 2 minutes then runs fine again (Whynam)
Check your main relay and go from there.....
Old Jun 9, 2007 | 09:33 AM
MatrixShark's Avatar
Fuel vapor lock?
Old Jun 9, 2007 | 03:31 PM
importfan2's Avatar
sounds like something in the ignition system....check for fuel pressure and signal when it happens
Old Jun 11, 2007 | 12:13 AM
Whynam's Avatar
Default Re: ITR stalls won't start for 2 minutes then runs fine again (importfan2)
thanks guys!! greatly appreciated!
I checked the main relay I think it's fine. It hasn't happend since. It's embarassing when it does lol. I have a feeling it's the ignition taking it to the shop tomorrow :D
F20b97AccordLx
Jan 16, 2023 10:15 AM
explosive
Aug 21, 2009 04:30 AM
solofthesouth
Apr 9, 2006 06:52 PM
Rain_man
Feb 10, 2003 01:52 PM
