94 hatch won't turn
Need help please.....
Car just won't come back to life just die one day on the freeway left the there came back later on the afternoon and car came back to life drove it home parked next morning it wouldn't turn and here is what i have try so far.
New fuel pump
new fuel filter
no engine light no codes
changed the ecu
change the dizzy
i have spark
timing is on
crank and cam moves when i turn the key
checked all grounds
trying new spark plugs tomorrow
any more hints ill put up a video of what it sound when i turned the key
well here is the link... http://www.youtube.com/watch?v=advn31batME
New fuel pump
new fuel filter
changed the ecu
change the dizzy
i have spark
timing is on
checked all grounds
Guest
Posts: n/a
check to see if your getting fuel and the pump is turning on, trace the power to the fuel pump, and test that, then test the relay, then also test to see what the battery is reading at voltage wise, of than that you screw with the plug wires at all, make sure thoose are in the right firing order, sounds like they are thow
your not getting one of the 2, fuel or spark, so test all the plugs, and all the fuel
93grayeg
Aug 7, 2011 04:52 PM
dskater4111
18
Aug 5, 2008 10:43 PM
