Need Honda/Acura Mechanic's HELP Please! - My 94' Integra GS-R Died Tonight...
Old Jun 8, 2007 | 11:11 PM
deep6's Avatar
Default Need Honda/Acura Mechanic's HELP Please! - My 94' Integra GS-R Died Tonight...
hey guys:
reaching out to any honda/acura mechanics that might know what's wrong with my 1994 acura integra gs-r? i was on my way to a friend's house when i pulled up to a stoplight and upon idle my car died and all the check engine/idot lights came on. i noticed that prior to my car dying my idle dropped to around 500-600 rpms and my headlights seemed to dim as well while all this time the car seemed to stumble before actually shutting down. for a while i noticed in the mornings it would take longer to crank before firing up but, this would also happen after the engine has completely warmed up after driving on several short trips. at this point i have NO idea what's wrong...is it a fuel or ignition problem??
since then i'm able to start and drive the car but, again my idle dips down to about
500-600rpms stumbles and goes back up to the normal 700-750rpms. inaddition the
headlights dim a bit as well but the car doesn't die on me. here's a list of almost all OEM parts that i've swapped out on my car along with the miles in parentsis of how many miles i've put on each part: any help or information would be greatly appreciated...feel free and post up here or send me private message
thank you.
114,440 (current miles on my car)
Fuel Filter
Checked Distributor Cap/Rotor and Cleaned/Sanded Contact Points
Checked ALL fuses to see if blown in Engine and Underdash
Checked ECU for any trouble codes but none displayed, i probably cleared them when i pulled all the fuses first
104,691 (9,749)
Kirkland Battery
95,373 (19,067)
Main Relay
87,617 (26,823)
86,842 (27,598)
Thermostat
73,451 (40,989)
Ignitor and Coil
64,040 (50,400)
PCV Valve
56,961 (57,479)
MSD Spark Plug Wires 8.5MM
51,356 (63,084)
Denso Platnium Spark Plugs
*Still running original OEM alternator and starter.
Old Jun 8, 2007 | 11:50 PM
GO-FIGHT-KILL's Avatar
This is the Type-R section.
And making identical technical posts in different sections is annoying, especially when you knowingly post them in the wrong specific forums.
Not trying to be an ***, but come on man.
Old Jun 9, 2007 | 12:57 AM
rjgerolaga's Avatar
i'll be nice. alternator and battery.
Old Jun 9, 2007 | 02:24 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: (rjgerolaga)
I - G
Old Jun 9, 2007 | 05:04 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjgerolaga &raquo;</TD></TR><TR><TD CLASS="quote">i'll be nice. alternator and battery.</TD></TR></TABLE>
x2
sepetinswenze
Jul 14, 2008 12:28 PM
94delsolb16a2
Mar 7, 2007 11:46 AM
