B20Z in CT CHEAP!!
2000 b20z block bored 84.5mm, weisco 12.5-13.0 hand sanded pistons w/rings ( $500), shimmed oil pump for higher pressure, gsr crank gridle for high revs, mircopolished crank, NEW IN BOX water pump,rear main seal, main bearings, rod bearings all new in box from honda!! gsr oil baffle/pickup/oil pan...i''ll throw in a set of oem axles..all this needs are eagle h beam rods (honda size 3)...needed them for another motor...sorry!!
asking $750....i'm near danbury, ct
