cooling fan?
Old Jun 8, 2007 | 04:59 PM
vaporxx2006's Avatar
Default cooling fan?
my cooling fan doesnt kick on at all... my temp guage can be at full red and still no cooling fan, i just replaced the temp sensor, under the distributor.... the coolant level is full... my cooling fan fuse is fine, the car seems to overheat but it really isnt that hot... anyone have similar problems? or know what is going on?
thanks for any help in advanced!
Old Jun 8, 2007 | 05:12 PM
skylude23's Avatar
Default Re: cooling fan? (vaporxx2006)
im not sure but it could be the thermostat I had heating problems and i had to change everything , Radiator then thermostat then I changed my Head gasket now my car stays cooler than ever
Old Jun 8, 2007 | 05:21 PM
jmai86's Avatar
Default Re: cooling fan? (skylude23)
Get a copy of the service manual online, and use a voltmeter to test the lines from the radiator fan module (located under the passenger footwell, next to ECU).
I had a similar problem and fixed it with a $30 replacement module.
Old Jun 9, 2007 | 06:13 AM
smo0th's Avatar
Try running direct power from your battery to the fan to make sure it works.
Old Jun 9, 2007 | 06:38 AM
mattsnooz's Avatar
Default Re: cooling fan? (smo0th)
x2
yeah, to test the fan motor itself.
could be the module too. mine went aswell
Kenneth723
Jun 9, 2019 07:38 PM
Mike1971
24
Jun 1, 2016 06:01 PM
MyRed98Civ
Jan 11, 2014 06:51 PM
InterludeTypeR
Jun 20, 2009 08:13 PM
turbotime
Nov 14, 2005 12:45 PM
