Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
amsoil oil / tranny fluid
Old Jun 8, 2007 | 01:37 PM
lsvtec101's Avatar
Default amsoil oil / tranny fluid
I'm about to order some amsoil ftw! and I just wanna make sure im ordering the right stuff.
ASL SAE 5W-30 Synthetic Motor Oil: (12) 1 quart bottles
Synthetic Manual Synchromesh Transmission Fluid (MTF) SAE 5W-30 2qts?
This look right? Thanks
Old Jun 8, 2007 | 01:43 PM
norcal450's Avatar
Default Re: amsoil oil / tranny fluid (lsvtec101)
yep...
syncromesh FTMFW!
Old Jun 8, 2007 | 01:54 PM
exhaust_note's Avatar
Honda MTF is the best way to go. its like 6-7 bucks for 2 qts.
Old Jun 8, 2007 | 02:00 PM
lsvtec101's Avatar
Default Re: (exhaust_note)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exhaust_note &raquo;</TD></TR><TR><TD CLASS="quote">Honda MTF is the best way to go. its like 6-7 bucks for 2 qts.</TD></TR></TABLE>
That's what I have now and its notchy, was from day one. Im getting the oil so why not get some tranny fluid?
Old Jun 8, 2007 | 02:01 PM
FBPSidan's Avatar
Default Re: (lsvtec101)
Did you swap to the new MTF?
Old Jun 8, 2007 | 02:06 PM
WILD_WILL's Avatar
The masses seem to think the amsoil is better i will be putting in amsoil when the SI gets out the shop
Old Jun 8, 2007 | 02:07 PM
lsvtec101's Avatar
Default Re: (FBPSidan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBPSidan &raquo;</TD></TR><TR><TD CLASS="quote">Did you swap to the new MTF?</TD></TR></TABLE>
I have a 07, so im assuming I have the newer version of it from the factory. or not.
Old Jun 8, 2007 | 02:19 PM
FBPSidan's Avatar
I have an 07 too and i swapped to the new fluid... so much nicer. From what im told the first "x amount" of the 07's had the oild fluid and they switched to the new stuff but noone knows for sure.
Old Jun 8, 2007 | 02:31 PM
lsvtec101's Avatar
ordered the amsoil oil and tranny fluid ill let you know how i make out.
Old Jun 14, 2007 | 09:56 AM
lsvtec101's Avatar
just finished changing the oil and tranny fluid. took the car for a ride, what a difference! i was suprised that it only took about 1.5qts of tranny fluid thou? I drained as much as i could and filled it until it over flowed.
Old Jun 14, 2007 | 11:03 AM
bourgeoisx's Avatar
is you 07 an si? and did you ever check your oil befor you changed it? why i ask in because i got an 07 si, a little over 2 months old and my oil is at 30% so i about to change it. i poped my hood the other day to check it and it is really low. the oil on the stick was less than half way untell the 1st dot. i did not think i would burn that much oil. just seeing if your was low.
Old Jun 14, 2007 | 11:11 AM
MonkeyConQueso's Avatar
Default Re: amsoil oil / tranny fluid (bourgeoisx)
It seems to me that the "break in" oil that's in there for the first 3-5k miles burns off easier than anything else you put in after. But have the dealership check everywhere for leaks just in case (I had a leak at the vtec switch).
If it's really low, put oil in.
Old Jun 14, 2007 | 11:35 AM
faster Type R's Avatar
im changing my oil soon...i guess i could pick up some tranny fluid while im there
Old Jun 14, 2007 | 11:55 AM
IT GUY's Avatar
Default Re: (faster Type R)
new Honda MTF did the trick for my 07 SI... but I bought it in december, so it was one of the first 07's I guess that had the old fluid...
Old Jun 14, 2007 | 04:55 PM
haby red fg2's Avatar
i have the amsoil syncromesh and competch ss shifts like a dream now
Old Jun 14, 2007 | 11:58 PM
ourmanritter's Avatar
anyone know where there's some documentation to confirm that the new model # (9031 i think?) honda mtf is actually reformulated?
i've read some conflicting stories. guys saying the parts guy said there's no new formula, just a new model number.
at my dealership, one guys says he doesn't know anything about it, and the other guy says he heard about it but doesn't think it's happened yet...
i guess i'll start calling some other dealerships to see what they say.
i know a lot of guys have posted that they noticed a big difference after swapping to the new mtf, but i need to be confident this is for real, otherwise i'll just get the amsoil.
Old Jun 15, 2007 | 07:06 AM
pinchycm's Avatar
Default Re: (IT GUY)
the new honda mtf didn't work for me. it was good for about a week.
i've switched to amsoil and it feels like a whole new gearbox. only time will tell, but the initial results are promising.
Old Jun 15, 2007 | 07:27 AM
KoalaEatingTree's Avatar
Default Re: amsoil oil / tranny fluid (MonkeyConQueso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyConQueso &raquo;</TD></TR><TR><TD CLASS="quote">It seems to me that the "break in" oil that's in there for the first 3-5k miles burns off easier than anything else you put in after. But have the dealership check everywhere for leaks just in case (I had a leak at the vtec switch).
If it's really low, put oil in. </TD></TR></TABLE>
A brand new Honda should not "burn" oil. If your car burns oil that is bad news. If the engine has 0 miles on it then the oil that is in there has to work its way into all the nooks and crannies of the engine internals, oil filter, etc. After that initial set-in period you shouldn't see your oil level dropping consistently, regardless of how much.
Old Jun 15, 2007 | 07:35 AM
TRE_'s Avatar
Default Re: (ourmanritter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ourmanritter &raquo;</TD></TR><TR><TD CLASS="quote">anyone know where there's some documentation to confirm that the new model # (9031 i think?) honda mtf is actually reformulated?
Honda doesnt not just slap new part numbers and labels on things for fun; the new 9031 fluid is a reforumlated MTF. When I was working at Honda we got a notice regarding what was changed about the fluid and why, and we also got one case so that our Tech's could sample it. It will make a difference if you're having slight 3rd or 2nd gear issues. AMS is a good alternative but I had no need to switch to something like that.
Old Jun 16, 2007 | 02:02 PM
Default Re: (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">
Honda doesnt not just slap new part numbers and labels on things for fun; the new 9031 fluid is a reforumlated MTF. When I was working at Honda we got a notice regarding what was changed about the fluid and why, and we also got one case so that our Tech's could sample it. It will make a difference if you're having slight 3rd or 2nd gear issues. AMS is a good alternative but I had no need to switch to something like that.</TD></TR></TABLE>
how recently did you work for honda? i thought this new formula is a very recent release...
Old Jun 16, 2007 | 02:53 PM
TRE_'s Avatar
I quit in Febuary of this year but we recieved our first case LONG before that... It took time to phase out all the "old" fluid so thats why its just recently been talked about more.
Old Jun 17, 2007 | 11:42 PM
that's pretty recently...
Old Jun 19, 2007 | 04:44 PM
Agent_EM1's Avatar
I wanna try out this amsoil stuff
Old Jun 22, 2007 | 01:57 PM
primalady's Avatar
Hi, this is my first post. I have a 2007 Accord EX with 3500 miles on it. I checked the fluids last week and found my oil to be a quart low, I was not too surprised by this because of the break in period. I checked the trans, fluid and it was 1/2 quart low and I did think that was strange (maybe I missed that in the owners manual). Does anyone know if that is normal? I have not noticed any problems but good thing I checked. Thanks for any input you can give.
si0385.
Dec 27, 2005 03:21 PM
1JDMDOMINICAN
Sep 23, 2005 12:38 PM
canzures
Apr 3, 2004 05:39 PM
civichb92
36
Oct 19, 2003 06:32 PM
buzz_worthy321
10
May 18, 2003 06:50 PM
