still not quit right
Old Jun 8, 2007 | 01:34 PM
B16tyler422's Avatar
Default still not quit right
JDM B16A Obdo in a 91 hatch im getting a 10 ,14, and 21 error codes in the ECU i changed the plugs, cap and rotor but when i step on the throttle or manuely engage it on the throttle body it hesatates then revs u hear the intake pull air in but it hesitates for just a sec then when it comes back down to where idle would be it sounds like it wants to die and barley catches it self. im stumped anyone have this problem B4?
Old Jun 8, 2007 | 02:03 PM
jlicrx's Avatar
Default Re: still not quit right (B16tyler422)
codes 10 and 14 at the same time usually means that you have the connectors for the IAT and EACV switched - IAT has red/yellow and green/white wires - EACV has blue/yellow and black/yellow wires - if the car was a DX, you could also have the connector for the Tandem Control Valve plugged into one of those sensors
Old Jun 8, 2007 | 07:32 PM
Default Re: still not quit right (jlicrx)
ok i checked the wires they are the red/yellow and green and white so thats hooked up right . now im checking my TPS to c if it is set at the right volts do u kno what it should be at , and would that effect the hesitation of the trottle response? and im getting the 21 code thats the Vtec soleinoid wire? correct? would it be because its not wiried into the ECU correctly. it has 2 wires coming from it a blue one and then a black with a yellow stripe i asumed that is a ground.
Einhander276
Feb 15, 2011 06:19 PM
UnknownKid
Jan 13, 2011 08:07 PM
brakedrum
Oct 16, 2010 08:57 PM
digitally_remastered
Jul 16, 2006 04:12 PM
turbo92subaru
Jan 31, 2006 10:15 AM
