Auto ECU
Old Jun 4, 2002 | 12:05 PM
wronghand's Avatar
Default Auto ECU
I have a buddy with a 91 DX hatch. He is having some problems with his automatic tranny. He is considering doing the 5 speed conversion. I have everything he needs to do the swap except the ecu. I know that the car will run with the auto ecu. My question is: Will this cause any problems other than the check engine light and a code 19.
Thanks in advance.
Old Jun 4, 2002 | 06:02 PM
wronghand's Avatar
Default Re: Auto ECU (wronghand)
Anyone?
Old Jun 4, 2002 | 07:04 PM
USDM 4G VTEC's Avatar
why change ECU's?? u can use a auto ecu on a manual
nottin changes actually... just one pliug for reverse
Old Jun 6, 2002 | 05:13 AM
wronghand's Avatar
Default Re: Auto ECU (JDM EF9)
Anyone else have any thoughts on this?
Old Jun 6, 2002 | 06:39 AM
24seven's Avatar
i've always been told you can't use the auto ecu, but i'm not a guru.
i changed to a stick at the same time i changed to mpfi, so ithrew in an si ecu.
Old Jun 6, 2002 | 07:08 AM
wronghand's Avatar
Default Re: Auto ECU (24seven)
He plans on doing the mpfi swap as well. Just doesn't have all the parts or funds right now to do so. That is why I am trying to find out if his auto ecu will present any problems.
I really don't think it will be a problem. Sometimes I get a little paranoid about this kind of stuff.
Old Jun 6, 2002 | 08:10 AM
HF2ZC's Avatar
You ought to just go look at the junkyard for an ecu. DX ecus are very common and very, very cheap. I believe that any ecu from an 88 - 91 DX (body style doesn't matter) will work. Look out for the Std. civic (4 speed hatch), though because it may have a different ecu.
Old Jun 6, 2002 | 04:53 PM
goforbroke's Avatar
MEAT PATTY
Default Re: Auto ECU (HF2ZC)
I have a b16a in my civic with a automatic ECU it runs fine, and the check engine light doesn't even come on.
A friend of mine has a automatic DX sedan, and I hook up my old si computer to it and it wouldn't even run, I car would barely start, so I don't know just try it
jdmcivicferio
Acura TSX
Nov 4, 2011 09:06 PM
mastech
Oct 8, 2011 10:10 AM
98savage
May 2, 2007 09:01 PM
Styler93GSX
Feb 2, 2004 03:28 PM
