H22 eg track times? HP numbers?
Old Jun 8, 2007 | 04:28 AM
matt94z's Avatar
Default H22 eg track times? HP numbers?
Hey guys I have a 94 ex coupe w/ B16 swap... .but for some stupid reason nothing is ever good enough, so Im kicking around the H2B swap. What kind 1/4 mille times are the H22 EG's running? Also any dyno numbers?
Thanks, Matt
Old Jun 8, 2007 | 08:01 AM
hpi247's Avatar
Default Re: H22 eg track times? HP numbers? (matt94z)
should be around very low 13s to mid or high 12s. all depends on driver, mods, slicks/street tires. too many variables. i will let you know what i run with my h2b eg when next friday comes around
Old Jun 8, 2007 | 09:20 AM
Mikey3000's Avatar
Default Re: H22 eg track times? HP numbers? (hpi247)
when my motor wasn't turboed i ran a 14.1@99 mph on some really shitty tires (175-65/13) goodyear aquatread and it had 9.0:1 pistons.
i'd say a stock H22 in an EG with slicks should be able to run 13.3@100 mph.
Old Jun 8, 2007 | 11:04 AM
matt94z's Avatar
Default Re: H22 eg track times? HP numbers? (Mikey3000)
Wow! Thats lower than I expected!...... The only mods I'll have are header, cold air, 2.5" exhaust, and a custom wideband O2 tune. I also have an SIR LSD trans.... so spinning wont be too much of an issue....
Old Jun 8, 2007 | 07:47 PM
hpi247's Avatar
lol u say that now. you should be able to pull off 13.5s pretty soon.
Old Jun 8, 2007 | 09:16 PM
nicksamba's Avatar
You will still spin...200HP+ with a FWD...you will spin some.
Old Jun 9, 2007 | 08:10 PM
2fastGSR's Avatar
King of the One Liners
lsd only means both tires will be spinning
Because- with this swap you WILL spin street tires.
Old Jun 9, 2007 | 08:24 PM
RotiEatter's Avatar
Ditto
I did 13.5 with my h22 eg
Old Jun 10, 2007 | 09:26 AM
h22civ's Avatar
Default Re: (RotiEatter)
My best run just on motor was a 13.04 @ 104 in the 1/4 mile. I cut a 1.6 on my 60 foot time which is really damn good. I used my 22.0 MT slicks. I have I/H/E and a good tune.
Old Jun 10, 2007 | 12:59 PM
HeikDiesel's Avatar
Default Re: (h22civ)
what did your car put down with i/h/e?
Jsherrod
Jul 5, 2015 06:15 AM
DJsilkyjr
Oct 24, 2006 04:49 AM
compdog694u
Oct 12, 2006 02:00 PM
Morhpeous
Jul 11, 2004 03:59 PM
fastwanabe
17
Mar 27, 2003 08:27 AM
