header mount?
I have shorty megan headers, just wondering if you need to mount it at the bottom? Dont know if it will damage them just bolted to the block. thanks
it is header, and are you pairing it up with a test pipe? because its going to bottleneck at the cat and you wont see any real gains. Just use the factory bolting points.
I was wondering if I needed to use the bottom bracket cause I could not get it off the stock piece. also I will be ordering a test pipe soon.
