Bad clutch?
Old Jun 7, 2007 | 07:13 PM
EFinawesomeman's Avatar
Default Bad clutch?
So I have a B18a1 with basic bolt ons in the car, clutch and lightweight flywheel both made by ACT. Now when I shift into third gear it grinds SOMETIMES but not all the time. and when I open it up and shift it grinds 3rd and 4th, a little birdy told me its my "throw bearing" thats causing it, when i think its just hte clutch. What do you guys think it could be? I was also considering that the synchronizers are just out of alignment. I am planning on rebuilding it anyway, just thought i would fix it before I go to the EF meet on the 16th
Old Jun 7, 2007 | 07:25 PM
Default Re: Bad clutch? (EFinawesomeman)
Any ideas?
Old Jun 7, 2007 | 07:47 PM
no one?
Old Jun 8, 2007 | 07:51 AM
I would like to knowwwww
Old Jun 8, 2007 | 08:17 AM
wickedEFguy's Avatar
When you shift does it only grind at higher RPM's or does it do it all the time?
It's really common for our old cable trannies to grind so try throwing in some GM synchromesh. Should cure most if not all the problem....You can get it at autozone in the gear oil section, Comes in a Yellow bottle and is made by penzoil.
Old Jun 8, 2007 | 08:18 AM
Default Re: (wickedEFguy)
yeah 3rd Yes 3rd and 4th grind everytime when i beat on it. but when im just rollin through town third gear just kinda like gets that stuck feeling and grinds.
Old Jun 8, 2007 | 10:52 AM
Default Re: (EFinawesomeman)
I bet the synchro's are starting to go out...Try putting in some GM synchromesh and see how it reacts. It should cure the problem but if it doesn't its time for either a rebuild or the search for another cable trans.
ADAMnQuickRDX
Transmission & Drivetrain
Jan 15, 2010 02:51 PM
suken19
Mar 21, 2006 10:00 AM
ablack934doorcivic
Nov 1, 2005 02:02 PM
WRTEG
Sep 4, 2004 05:08 PM
Chief Brody
Aug 4, 2004 09:28 PM
