Honda S2000 Honda S2000
aftermarket alarm install.. my driver side door isnt locking or unlocking
Old Jun 7, 2007 | 04:52 PM
J.nguyen's Avatar
Default aftermarket alarm install.. my driver side door isnt locking or unlocking
https://honda-tech.com/zerothread?id=2007659
help me out..
me and friend are in mid of installing alarm and everything is done except for this problem
Old Jun 7, 2007 | 05:57 PM
WowOzYouRock's Avatar
Default Re: aftermarket alarm install.. my driver side door isnt locking or unlocking (J.nguyen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.nguyen &raquo;</TD></TR><TR><TD CLASS="quote"> me and friend </TD></TR></TABLE>
thats the problem...
Old Jun 7, 2007 | 07:28 PM
J.nguyen's Avatar
Default Re: aftermarket alarm install.. my driver side door isnt locking or unlocking (FR-MOB: Jerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk &raquo;</TD></TR><TR><TD CLASS="quote">thats the problem... </TD></TR></TABLE>
aha i trust his abilities, he's done alarm install on alot of ppls cars, no probs, & he does do it at bestbuy for his job..
well wierd thing is right now after driving it home, it actually does lock and unlock, but sometimes it doesnt unlock or vice versa.. (driver side only) passenger side works perfectly .. we are stumped since it was working perfectly before alarm install.. but did research taht A LOT of ppl are having this problem with their keyless entry and most answers are unresolved on s2ki
Old Jun 7, 2007 | 07:32 PM
are you talking about locking it hand or remote?
Old Jun 7, 2007 | 07:46 PM
Mr. Projekt's Avatar
* B A N N E D *
There's no power door lock by hand.
Old Jun 7, 2007 | 07:50 PM
J.nguyen's Avatar
Default Re: aftermarket alarm install.. my driver side door isnt locking or unlocking (Mr. Projekt)
lol yeah by remote, and you know when you turn on the car and off, it locks and unlocks by itself, well passenger is working, dirver side isnt. ive been searching on s2ki and 12volt ... wow so many ppl have this problem on their OEM keyless entry remote..
i guess its a problem alot of ppl are having
Old Jun 7, 2007 | 07:52 PM
* B A N N E D *
Did you incorporate the OEM keyless entry unit into the Viper alarm? Most problems arise when people try this, instead of directly wiring the lock cylinder actuators to the alarms control unit itself.
Old Jun 7, 2007 | 07:57 PM
i know.. i had an AP1 remember?
when i lock mine by hand, i had to pull the lever slightly first then push the lock..
Old Jun 7, 2007 | 08:27 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Did you incorporate the OEM keyless entry unit into the Viper alarm? Most problems arise when people try this, instead of directly wiring the lock cylinder actuators to the alarms control unit itself.</TD></TR></TABLE>
yeah we incorporated the keyless entry unit to the viper alarm. so we shouldnt have done this?
Old Jun 7, 2007 | 08:39 PM
* B A N N E D *
yeah we incorporated the keyless entry unit to the viper alarm. so we shouldnt have done this?</TD></TR></TABLE>
Like I've stated, people who have done so have had problems with the OEM unit interfering.
Old Jun 7, 2007 | 11:25 PM
niccuhles's Avatar
your lock motor might be fugged. if you hear it going but it isnt going, the actuator might be bad. also check your alarm wire too...
The doorlocks on s2000s are located behind the start button in the keyless entry module and is a 5 wire system(you need a DEI 451m relay box to do so). youre friend should know what a 5 wire system is if he's a pro installer.
Locate your factory lock and unlock wire..
Lock=Pink/black
Unlock=Yellow/Green and pink/blue(use either one)
cut the 2 wires in half.
Using the 451M relay attach...
white/black(451m) to pink/black(car) switch side.
green/black(451m) to pink/black(car) to lock motor side.
brown/black(451M) to yellow/green or pink/blue(car) switch side.
blue/black to yellow/green or pink/blue(car) unlock motor side.
attach purple wire(451m) to 12v.
wire that and it should work perfect. if not actuator is done for.
Modified by niccuhles at 12:36 AM 6/8/2007
Old Jun 8, 2007 | 06:03 AM
BlueSi2k's Avatar
Default Re: (niccuhles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niccuhles &raquo;</TD></TR><TR><TD CLASS="quote">your lock motor might be fugged. if you hear it going but it isnt going, the actuator might be bad. also check your alarm wire too...
Lock=Pink/black
Modified by niccuhles at 12:36 AM 6/8/2007</TD></TR></TABLE>
I second this. One thing though, I think you may have to use both the yellow/green and pink/blue as if I remember correctly one is for the driver door and one is for the passenger door (pressing unlock once only unlocks driver door). When I did mine I just used 2 relays (same as 451m). I hooked both wires to the unlock output from the relay and everything works fine.
Old Jun 8, 2007 | 03:20 PM
J.nguyen's Avatar
Default Re: (BlueSi2k)
thats exactly what we did though , pretty sure our wiring is correct, or else the passenger door wouldnt work how it is..
Old Jun 8, 2007 | 03:25 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Lock=Pink/black
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueSi2k &raquo;</TD></TR><TR><TD CLASS="quote">
I second this. One thing though, I think you may have to use both the yellow/green and pink/blue as if I remember correctly one is for the driver door and one is for the passenger door (pressing unlock once only unlocks driver door). When I did mine I just used 2 relays (same as 451m). I hooked both wires to the unlock output from the relay and everything works fine.</TD></TR></TABLE>
I am the one that installed his alarm, i am MECP certified too so i know what i was doing as far as how to install alarms. his problem was unique to his vehicle. after doing research i came to a conclusion that 2000-2002 S2000 have this problem a lot. it requires aftermarket actuators or repinning the factory power lock relay.
Old Jun 9, 2007 | 02:15 PM
J.nguyen's Avatar
Default Re: (JDM turbo DC)
ef-hatchcrap
Audio / Security / Video
Nov 24, 2007 08:54 PM
FBPSidan
Feb 23, 2006 08:05 AM
goku28
Apr 7, 2005 05:46 AM
teggydog
Mar 16, 2005 02:46 PM
RGoose18
Oct 30, 2003 11:03 AM
