Valve Seat Pressure under Boost/Flow numbers
Old Jun 7, 2007 | 04:25 PM
elevatedj32's Avatar
Default Valve
e
Modified by elevatedj32 at 6:18 AM 6/10/2007
Modified by elevatedj32 at 6:19 AM 6/10/2007
Old Jun 7, 2007 | 04:42 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
umm... why did you black out what head you're using?
Old Jun 7, 2007 | 06:21 PM
Jared's Avatar
spring pressure will also depend on your camshaft, not just boost pressure.
Old Jun 7, 2007 | 06:22 PM
Default Re: (full Circling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by full Circling &raquo;</TD></TR><TR><TD CLASS="quote">umm... why did you black out what head you're using?</TD></TR></TABLE>
better? it's a j32v6,
Old Jun 7, 2007 | 07:29 PM
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">spring pressure will also depend on your camshaft, not just boost pressure.</TD></TR></TABLE>
is this because too high of a spring pressure will cause premature wear on the cam? or is it something else?
Old Jun 7, 2007 | 07:30 PM
Jared's Avatar
because more lift and duration of the cam shaft requires more spring pressure to put the valve back on the seat to avoid float.
xjdmjunkiex
Jul 15, 2012 10:45 AM
hyboost
Jul 3, 2009 05:54 PM
mrx
Jul 30, 2007 12:39 PM
turbo boost
Jan 1, 2007 03:39 PM
